4.8 swap/turbo alternator bracket setup
Old Mar 16, 2013 | 06:40 PM
jonahs_supra's Avatar
Default 4.8 swap/turbo alternator bracket setup
Im currently in the process of finishing my 4.8L swap up
A little info:
91 Supra
2001 4.8L/4L60E
GT45 turbo
Truck manifolds flipped(vbands)
LS1 intake
The problem im having is how/where to mount the alternator(01 silverado alternator)
Im not running powersteering at this time and running electric cooling fans
With room being the major issue.
How does everybody go about mounting their alternator with the truck manifolds flipped forward
I need the alternator to be no higher then the throttle body(1/2" of clearance between TB and hood)
Thanks for any help
A few pics
How it sits as of right now
Passenger manifold clearance
Driver manifold clearance
Old Mar 16, 2013 | 08:21 PM
WSex's Avatar
getting the relocation bracket so the alt sits on your left head.
Old Mar 16, 2013 | 08:31 PM
Relocation bracket?
Ill do some research
Old Mar 16, 2013 | 08:44 PM
jrpimp00's Avatar
I got the CBR relocation bracket, a but pricey, but it worked perfect for me, but this is under a ram air T/A hood
https://ls1tech.com/forums/forced-in...ation-kit.html
Old Mar 16, 2013 | 08:50 PM
I saw that bracket kit.
Appears to be about 2" higher then the Throttle body would be
I have 1/2" of clearance between throttle body and the hood
Thanks anyway
Old Mar 17, 2013 | 11:03 AM
LS1NOVA's Avatar
The Holley, Kwik Perf, or Speedway bracket mounted to the left head.
Old Mar 17, 2013 | 01:18 PM
ronnieforrester's Avatar
use stock f body mount- angle hot side around alternator.
Old Mar 17, 2013 | 02:24 PM
TheLS1Lover's Avatar
I would add V-Bands to the Manifold. You can also do a Low Mount Alternator Bracket from AEI CNC.
