Blow through 6.0 S480 - 1067hp
#46
Thanks . It is the same 16psi waste gate springs it had on the dyno at 1067 flywheel. Using a rwhp calc I have shows 870 to the tire based on the 3510 race weight . There is power missing somewhere, I'm guessing the air conditions?? I did not pay attention to that as I expected the car to spin and not make a decent pass.
IAT's were 120ish at start line creeping to 205 ish at the finish line.
60 fts are slow too at 1.52's
I'm still pumped about it!
#50
Congrats on the dyno numbers and amazing track times! Is the cam the same cam you ran before when you were na or did you get a custom turbo grind cam? Planning on lq9 in my
69 nova that won't be turboed right away
#51
This same cam and engine combo ran 11.39 @ 120 in this car , N/A @ 3425lbs in 2010. I got it used off the classified section here.
That LQ9 has different heads and will probably want a different cam for best results, but I'm sure this same cam will still run great in it regardless.
