stock truck intake and high boost??
Old Apr 6, 2013 | 09:41 PM
mustang93's Avatar
Default stock truck intake and high boost??
Im building a stock 2007 6.0 mustang. GT91mm E85 turbo cam. Glide. anyone making big power and running good numbers with a stock truck intake? Only one i have found is mayham motorsports 5.3 turbo mustang.
Old Apr 6, 2013 | 09:52 PM
Blackpanther99's Avatar
That intake will probably restrict some good power.
Old Apr 6, 2013 | 10:28 PM
tennerv8's Avatar
For all you truck intake haters, that blue fox body on here is in the 8's with a truck intake.
Old Apr 6, 2013 | 11:44 PM
denmah's Avatar
Moderator
yep my friends is running 24psi and going high 8s 153mph
proven
Old Apr 7, 2013 | 09:39 AM
foose04's Avatar
If it's a NNB or TBSS stye I made 880HP thru a 4l80 at 22psi. I think it's seemed to work fine. Also ran the stock truck 78mm throttle body.
Old Apr 7, 2013 | 11:24 AM
01snake's Avatar
What size coupler are you guys running for the throttle body side?
Old Apr 7, 2013 | 09:57 PM
denmah's Avatar
Moderator
3.75 from Miragepower2008 on ebay
"jdm racing" is the brand he sells, the 3.75 slips over a stock throttle tight, fits great.
he sells strait, reducing, and reducing 90s for like 16 a piece, all of them
Old Apr 7, 2013 | 10:12 PM
proven
Thats is very amazing.
Old Jul 30, 2013 | 08:06 AM
Tuckin15s's Avatar
Sorry to dig a old thread up, But how much boost can the TBSS intake take before it starts to lift or separate? Have any of your guys ran into this problem?
Old Jul 30, 2013 | 05:02 PM
denmah's Avatar
Moderator
they can all take more than the motor can.
Old Jul 30, 2013 | 07:52 PM
Twin turbo c5's Avatar
I've run 20 psi on stock truck intakes for awhile now.If it'll fit under your hood run it.
Old Jul 30, 2013 | 09:06 PM
RonSSNova's Avatar
Stock48 is barely getting by with one......
https://ls1tech.com/forums/forced-in...63-75-mph.html
Old Jul 30, 2013 | 10:47 PM
Tuckin15s's Avatar
Ok because over on Performance trucks I saw a couple guys having issues with the intakes separating and causing them to leak.
Old Oct 25, 2013 | 01:23 PM
Jamescassy's Avatar
Is a 2002 6.0 nnb ?
Old Oct 25, 2013 | 01:29 PM
denmah's Avatar
Moderator
a friend of mine and i built a 10 sec 4.8 truck
ran 26lbs thru it accidentally a few times, it was a 2010 so it had the tbss style with the large throttle body
it never separated, or had any issues, it would run 20-22 all day long, we fucked up and spiked it super high many times hahaha *connecting the wastegate wrong a few times*
no issues
