PROJECT RED ROCKET TUNING HAS STARTED! AES390, Twin turbo, 4l80e. PG21, Post 408! :)
#141
Im tryin to be as thorough as possible lol.
Thanks man!
Thank ya sir lol
Were gonna dump them right under the sway bar with a slash cut. hopefully its not too messy. Itd be a real pain in the *** to re-plumb them back in. sooooo, **** it. dumped it is lol.
Gonna finish the gates up this saturday after i buy a new blade -_-. Also ordering the cold side on friday and work on it next week. It should be a pretty simple install. Then I'll start coating/wrapping the hotside, and ahve the cold side powerder coated. Ive thought about wrinkle coating the charge piping to match the valve covers. What do you guys think?
Thanks man!
Thank ya sir lol
#144
They turned out pretty damn good on the valve covers. i was surprised. I bought aircraft paint remover with the VHT cuz i just knew it would **** up and id have to take it off...lol.. nope. turned out awesome. Ordering my IC/piping on friday. probably finishing the wastegates saturday.
Theres like 4 ppl that comment on my build thread lol. im surprised more ppl dont comment... weird haha
#149
little update. got the wastegates mounted and i got them all TIG'd up. the pics are from before i had them welded.. Only had on one dump pipe on but you get the idea. This was THE only place i could both of the gates to fit without having to either - A. redo the drivers side up-pipe, or B. mount the wastegate really stupid under the car. I gotta handit to some fabricators out there. its really hard to make **** fit. But i think itll work out ok.
My intercooler, piping, clamps and couplers will be here this week. Thanks to Jon @ Huron speed for hooking me up with the intercooler. (Wish you could tag people on the forum) My plans for right now are to get the intercooler mount, get o2 bungs welded into the hotside and get it coated and heat wrapped, then get the IC setup mounted and wrinkle painted. Then ill move onto finishing up some small things like hanging the fuse box harness and relocationg the battery, making a bracket for the radiator. Imma have to take a break from the car for a couple months because i want to pay some stuff off so i have more money to spend on her. Not to worry, she'll be done soon enough! Im not in any big hurry.
#151
thanks. ill be running the griffin radiator everyone uses. with a 160* Tstat with some kind of cooling additive. 2 10" cheapo zirgo pusher fans. The car has no AC. i think it will be fine. i don't drive it when its 90* out anyway. ill also be makin my own custom radiator lines out of 1 3/4" aluminum tubing and silocone couplers.
#156
Those gates are should make some noise. I know that's all I here once mine opens up.( behind pass side fog light pointed at ground) I kinda like it but at the same time I'd like to see how the car sounds with them recirculated.
#158
Sry bro, none yet lol. itll b awhile. ill do a big one just for you though when its done lol.
hopefully they dont drown out the turbos. annnd hopefully they dont open very often at 19-21psi lol.
nice. make sure to post results who built your th400? price? i know where i can get a built 80e with a brake good for 1000whp for $2600. tryin to decide if its gonna b a huge hassle to do an 80e
