Set me straight on pump gas
I have a local friend with a well built 03 cobra, and he spent a couple thousand dollars swapping his fuel system over to e85. bigger injectors, pump, new lines, etc etc... car made 10 more whp. and ontop of that, the car sat for about a month in the shop. the next time he cranked it up, it was running terrible. turns out in that time the e85 had corroded and destroyed his new injectors and some fittings started leaking from the fuel eating the rubber in the lines.
so you guys can have fun with all that, I will stay far away from the stuff. I have an air to water, so I should be able to bring my AIT's down enough to run comparable timing an power numbers
- 408/F1R Air to Air I/C=850rwhp on pump gas no meth
- 347/Novi 2500 Air to Air I/C=820rwhp on pump gas no meth
- 402/F1R Air to Air I/C=790rwhp on pump gas no meth
- Stock bottom end LS3/YSi Air to Air I/C=812rwhp on pump gas with dual 7gph meth nozzles. The methanol on this one was more so for added safety with the SBE.
None of these cars have over 18* timing advance up top and most are in the 12-14* range at peak torque IIRC. All of them are running 8 heat range plugs. The three built motors are in the 9.2:1-10.0:1 CR range with the SBE LS3 being the highest CR of all 4 that I mentioned with 10.7:1 which they come with stock.
BCR8ES
I did use it for a while on mine, but really didnt see the need going colder than a 7, so I'm back on a 7 now.
But there were no issues running the 8.
Yes. 6.0's in the 1/8th in a heavy car, stock suspension, full interior, sound system, sub woofers, street tires, and just learning to tune. I thought that was pretty solid. 118mph.
btw those are really good numbers for a street trim car. I am not arguing your success. I'm just saying that the same results can be had with regular pump gas, with alot less headache. I am shooting for 5.90's with my 5.3 at 3250 raceweight with air to water on pump at around 15-16 psi
Oh and his tuner obviously wasn't that great either. First time I switched to E85, I tossed a few more degrees of timing, a few extra PSI, and better fuel trims at it, and picked up a good 20% increase over pump gas that was at its peak on my setup because it was seeing detonation. No other changes to the setup.
my argument with it is:
people say you need about 20% more fuel system capability with e85 to run your same numbers because it takes more of the fuel to make the same power. why not upgrade your fuel system to handle that much more fuel and run pump gas? then how much power will you be making? I understand you can get more aggressive with timing, and that's cool and all, but what if you are putting more fuel to it and can just turn the boost up some to compensate? even if you have to pull more timing, you will still make more power than you were before
Plus it's a whole lot safer, and if your running 1000rwhp are you really worried about less mpg's??
