Set me straight on pump gas
If you cant understand that, then it's hardly worth the effort trying to make you understand.
Sometimes fools get ideas into their heads, and no matter how much truth or fact you try and tell them, they'll still listen to bullshit and believe it because it's what they want to hear and agrees with their delusional thinking.
And no, it is not what E85 is doing. Clearly you have no clue about any principals including how power is made !
this thread has brought to light just how many people have forgotten the basic principals of how power is made
Do you understand the simple fundamentals of octane ratings? Is 93 octane pump gas not 93 octane? Of course it takes added fuel to make more power with added volumetric efficiency. BUT there comes a point that with the cylinder pressures needed to create these higher VE's that the octane of the fuel you're using can't quench detonation. You seem to just not understand this or totally ignorant to the fact that there is only so much detonation resistance for a given octane. Of course adding more boost and adding more fuel to go with it will make more power, but when you have a fuel like E85 where you can increase compression, increase boost and increase timing to levels that pump gas would never tolerate, you tell me which one will make more power? The one with more octane will!
You seem stuck on the fact that you have to add more of it. You're right it has a lower BTU rating BUT it still has a higher OCTANE RATING! Just like methanol. If pump gas was so great, why the hell do we even run race gas or methanol in the first place?!?!
If you can't understand this, you should sit back and read a few books or do something other than spew this kind of nonsense.
I did go to "tech school" and grew up in my dad's shop building racecars, and my first job was in an engine building shop, which I still deal with. I like how everyone keeps coming in here saying "No, you're wrong. that's not how it works". well I am still waiting for one of you to kindly explain to us all how it does work then because right now all the information that is out there is against your argument. Again, sounds familiar doesn't it Mr. Smallwood? BTW have you made that call to SAM yet? No, instead of using facts and information, you resort to personal attacks. AGAIN. So, seeing as the title of the thread is "Set me straight on pump gas" why don't you set us straight on e85? since everyone I know who runs it, the guys on yellowbullet, popular hotrodding and all the other resources I found, obviously have it all wrong.
I question how much reading comprehension you have not to be able to see that everyone in that thread on YB is agreeing with me! Because of the higher concentrations of oxygen and it's higher octane rating....E85 allows the use of more timing advance, more compression, higher boost levels and it allows for cooler in cylinder combustion temps! All things that pump gas CANNOT do! E85 will make more power EVERY SINGLE TIME over pump gas and even most race fuels!!! Tell me again how pump gas can make more power over E85 or race fuel by just adding more fuel? I'm honestly not sure whether I should still be shocked by your posts because they are so out in left field it's frightening honestly.
It all comes down to this. If you can't wrap your head around higher octane ratings have more detonation resistance which allows for more compression, timing advance and boost to be utilized, then you'll never understand any of this. This is quite elementary and the fact that you're arguing such is sad.
my argument with it is:
people say you need about 20% more fuel system capability with e85 to run your same numbers because it takes more of the fuel to make the same power. why not upgrade your fuel system to handle that much more fuel and run pump gas? then how much power will you be making? I understand you can get more aggressive with timing, and that's cool and all, but what if you are putting more fuel to it and can just turn the boost up some to compensate? even if you have to pull more timing, you will still make more power than you were before
By your theory, I should be able to put e85 in my setup with stock injectors and make more power than if I ran pump gas on 36# injectors. And as discussed int he other thread, without upgrading the fuel system, it would be hard to make the same power numbers because you will not be able to flow as much fuel. You are then compensating with timing to be able to make the same power.
Now do you see how your argument looks? I'm sorry but you lost all credibility with me with the carb debate, and this one isn't helping. Maybe I should run a carb with e85 and defy all physics and have the fastest thing ever! I'm done here.
Bottom line, I am staying far away from the stuff. I have seen too many negatives out of it for the few positives I have seen. You boys have fun with that vegetable oil. I like driving mine
In terms of making power...only that same idiot would refuse the option of using E85 like you have done. That in itself speaks volumes.
I was there on cam day. I can lay claim to having my cams in some of the fastest LS powered vehicles in the country as well as some of the most powerful. What can you lay claim to? I'm 25 years old and can grind a cam as well as some of the guys that have been in this game for 20 years. I am very proud of that so thank you for the compliment.
Also the added fuel volume required by e85 isn't to "make the same power", it's simply to achieve an identical air fuel ratio as an identical set up on gas would. Due to its oxygenation, higher octane and cooling properties E85 will make MORE power on the same boost level. Then, you're able to add more timing on top of that and you're able to make even more power than you would on gas.
If you dont or can't understand this, please stop confusing others who may not know for themselves either.
I feel for the OP. This thread has spiraled out of control, lol.
if I find out my Aeromotive pump is e85 compatible I will, just to make a point, dyno my setup on pump gas with injectors at maximun safe duty cylce. then put e85 in with the same size fuel system, and retune accordingly to same injector duty cycle and redyno it. Just to have physical numbers that cannot be debated. Then we can see just what the truth to this matter is
and if you re dyno it on the same boost and duty cycle I cant wait to see pics of your motor upon tear down
so after all is said and done i think if he wants to run pump gas he needs to do a meth kit no??? haha
