Todays Challenge: What turbo for a 6.0L, 600hp, 2,300lb car...
I'm starting yet another new project, but this one is a bit off the wall. Not going to divulge all of the details, but here are a list of requirements/restrictions:
SMALL car, tiny engine bay
6.0L, head studs, rod bolts, small turbo specific cam *already on hand and must be used*
600hp at crank desired - no more than that, won't be able to put it to the ground...205 rear tire
Pump gas, non-intercooled
Single turbo
Turbo must be T3 sized, small frame - smaller the better
3" down-pipe max
Ball-bearing turbo not required/wanted for cost reasons
If you were wondering why not just do a N/A head-cam build? Idle quality is desired to be near stock. Car will be geared to do 1,800rpm or less at 60mph with a TH400 3-speed auto. This would greatly under-gear a N/A build.
So, what turbo would you choose?
Single turbo
3" down-pipe max
The car wont be fun to drive. Your either going to put a big turbo on the car and choke it with what your looking to do or put a tiny turbo and reach its max flow very fast with that big of a CI motor. I would say a Precision 6262 would be the way to go if you still choose this project.
Be careful with that combo...small inefficient turbos will raise the IATs...combine that with pump gas and no intercooler...it's a recipe for hurting parts.
How do I know? Last year I blew up a SBC with a 58mm T4, non-intercooled on 100 octane, with 20 degrees timing. Broke 3 pistons and cracked the block! High IATs = detonation...and detonation kills.
Single turbo
3" down-pipe max
Single turbo
3" down-pipe max
'86 Chevette here, 6.0L with either twin stock GN turbos or a single S475. Either way good luck.
Sell the 6.0, get a 4.8 or 5.3 for half what you sell that 6.0 for.
Get a newer Turbonetics 76 MM with the larger turbine wheel or a Precision 7675
Add some meth nozzles to the intake when you really want to romp on it.
Or, make provisions to run E85 and that will help your IAT's
With a 76 MM turbo and a 4.8, you are going to have 600+ WHP with the right tune even without an intercooler.
Single turbo
3" down-pipe max
Single turbo
3" down-pipe max
Trying to turbocharged a build for such a small increase in power borders on silly, especially when the turbo is just too small.
Of course it can be done though.
I think you are going to like this setup a lot better. A 5.3 or even a 4.8 with a 6262 or a GT35R should work just fine.
These On3 Performance turbos are actually very tiny and compact for a T4 turbo. I have a 76mm and I can't believe how small it is compared to the GT45 or BW's. Something to consider. Mine put down 485 rwhp the other day on the dyno at 10 psi, stock bottom end.
On3 pic: ($319 plus shipping).
http://www.ebay.com/itm/On-3-Performance-76mm-Turbo-Camaro-LS1-LS2-LS3-LS6-LSX-Camaro-Trans-Am-6-0l-5-3l-/140974408414?pt=Race_Car_Parts&hash=item20d2bac2de&vxp=mtr
