h/c advanced induction twin turbo setup ls1
Was thinking the same thing..
35MPG twin turbo setup?!? LOL
Get a huron speed truck manifold turbo kit, upgrade your fuel system, and you'll easily see 500 rwhp on a stock top end. You'll also want to look into upgrading the Stage 2 Monster as it's rated to only 550rwhp and you'll easily pass that figure with twins, or even a single.
https://ls1tech.com/forums/generatio...am-ls1-m6.html
https://ls1tech.com/forums/new-ls1-o...-trans-am.html
https://ls1tech.com/forums/generatio...m-ls1-ls6.html
https://ls1tech.com/forums/pontiac-f...heads-cam.html
https://ls1tech.com/forums/generatio...l-economy.html
Not sure if he's being serious
![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
Cute, guys. I thought real men were on here, but I guess the children sneak on here too. Call advanced induction. You yield nearly the same MPG with a 243 ported polished heads/cam matching set and upgraded valvetrain
I'm sorry, I'm very new to this whole car thing. Could you explain how more fuel and more air into an engine give me better gas mileage? If this is true I should get a BBC or Hemi for my Fox.
Found gt35 turbos with ceramic ball bearings for $200 a piece. I'm going to start fabrication once I receive them. Is it true that CX racing and GodSpeed are EBay brands/sellers?
What are the specs?
Thnx.
It's not 35mpg from the heads/can't. The port/Polish and better flowing heads increase the efficiency of the engine. Adding a Turbo and lowering the compression increases the efficiency even more while using only a little more fuel. But the recycling of energy and power through the Turbo yields better MPG/fuel economy
You need to slow down with this whole twin turbo idea. It seems you know very little about it and are just digging yourself into a hole with spontaneous purchases. A well thought out and effcient turbo system is an art not just something thrown together after 5 minutes on ebay.
#33
#35
![Popcorn](https://ls1tech.com/forums/images/smilies/popcorn.gif)
#37
#38
You're correct, but adding boost to a decompressed motor increases the efficiency. You can't take a few words out of my sentence and say I'm wrong Lol. I said Adding a Turbo And lowering your compression yields better efficiency. I was referring to having a higher compression ratio after the heads and cam
#39
Those gt35 turbos are most likely cheap knock offs.. if you want authentic Garrett you need to purchase through a well respected dealer/vendor.
