injectors help
Old Jul 11, 2013 | 05:40 PM
trans2000am's Avatar
Default injectors help
just got my car dyno'd currently 60lbs injectors in the car, well im almost near maxing them out at 8 pounds lol. going to be looking for a new set soon and go back to the dyno. with all the vendors etc what are some good reliable injectors that are good for the street?
i will be cranking it up to atleast 20lbs
thanks
Old Jul 11, 2013 | 09:11 PM
shawnc16's Avatar
What fuel?
Old Jul 12, 2013 | 04:11 AM
currently i believe 110 have to find out from my tuner today
Old Jul 13, 2013 | 07:17 AM
mrstepheneades's Avatar
thanks
Im a stock ls1 longblock for exception of cam with s475 on 8psi. Im running the FIC1000cc injectors. They are 95lb@43.5 psi and 103.5@ls1 pressure of 58psi.
I have twin walbro 340s in tank.
Great injector and at my current horsepower around 520-530rwhp they are less than 40% duty cycle. Cost me 599.99 through TickPerformance. Martin suggested them because they are easy to tune with an can handle being turned down for my power level but at same time I can grow to way way more power if I so desire in the future. Just didn't wanna have to buy things twice as you are going to have too lol.
Old Jul 14, 2013 | 07:54 PM
bad6as's Avatar
Need more info on your car. What pump and what size lines. And 8lbs on what a tc76 or a gt55-94 .or a blower? Need mor info
Old Jul 14, 2013 | 09:20 PM
twin 340's, 8" feed and 6 return, FPR. large frame turbo grudge car so i wont go into numbers but with the drivetrain(th400,9",28 tall tire) it put some power down
Old Jul 14, 2013 | 09:25 PM
bad6as's Avatar
must not be that fast of a grudge car if your feeding it with twin 340s and a -8 feed.
if you want help you need to share info. something in the 100lb at 58psi range should get you around 1100 crank hp. if thats not enough fic sells some 127lbs and then there are id2000s
Old Jul 14, 2013 | 09:30 PM
bad6as's Avatar
if you grudge race the car, im assuming the info in your sig isnt correct. but that s85 should be able to max out some id1000s so if your more then that s85 go with the fic127s
Old Jul 14, 2013 | 09:31 PM
feed and pumps were plenty enough i was told from the tuner just the injectors i knew the injectors would be an issue just lefted them in due to the pass tune was already set for them and wanted to see how far i could take them.if the lines and pump becomes an issue ill just swap them out no big deal, this is still a street car. I will look into FIC
Old Jul 14, 2013 | 09:34 PM
yea havent updated that
