Dual meth nozzle placement
The car is just a toy. I dont drag race it. Just a fun car to go beat on when I feel like it. I take the car on trips etc...
Honestly dude, going with 100% meth or going with 50:50 water meth mix, both will be benefitial, both will do their job at keeping you away from detonation. Neither one will lead to bad things if setup properly.
It will be less corrosive and safer to handle if it is a 50:50 water meth mix.
You need to use purified or distilled water (I just buy mine from the grocery store). Do not use tap water.
Some people say its okay, but I would not recommend using washer fluid as your source of methanol.
ONE RIGHT AT THE INLET OF THE INTERCOOLER, SECOND 6" FROM THE OUTLET OF THE INTERCOOLER AND THE THIRD IS 18" FROM THE TB.
15GPH,14GPH,9GPH AS I POSTED THEM.
STOCK 5.3 TRAPPING 143MPH AT 20PSI ON A 92DEG DAY IAT WAS 79DEG AT THE END OF THE RUN.
IM RUNNING ON 2YR OLD METH, IT DOSE NOT GO BAD,
YES YOU CAN RUN A TON OF METH...... BUT IF THE PUMP FAILS AND ITS TUNED TO COMPENSATE THE METH IT WILL GO LEAN AND PO THE ENGINE...
MY TUNE WITH OUT METH WILL HIT 13AFRS VERY FAST, SO THERE IS A BALANCE.
i SHOOT FOR 11.0 DOWN LOW AND LEANS OUT TO 11.9 ON THE BIG END.. ON E85
The tanks not going to explode in the heat, but I agree its a good idea to have it vented. I don't know what the freezing level of meth is, but I would guess its pretty damn cold. I have left my water meth mix stay in an un-heated garage during temps well below freezing in northern Indiana and had no issues.
9sectruck brings up a good point. I keep bringing up "its safe if its setup properly" but I guess I should throw in a big key point for someone learning here that may not know.
When your car is tuned on meth, if you plan on using it to lower your IAT's and run more timing and boost safely (as most of us who use it do), then your tune will be depending on the meth to keep it safe. Run the car that's tuned on meth and the meth stops working for some reason, and your higher boost and timing without the meth can mean very bad things for your motor. Some people don't want to do meth injection for this danger alone.
There are ways to be protected. #1, and almost most important, you need to have a wideband O2 sensor and gauge in the car so you can monitor your AFR's and keep them safe. If things start to go lean while getting in the boost you can see this and if its in enough time, get out of it before you do any damage.
I have rigged up a sensor in the meth line that once it senses meth spraying it shows me a green light in my car. So as long as I see the green light out of the corner of my eye, I know I'm safe.
Snow Performance offers a "safe injection" system that also monitors the meth, and if something isn't working right, it automatically retards your timing and cuts boost to keep you safe. I believe Snow Performance is the only meth injection company that offers such a system.
I run the blue stuff (-30F) and I run it right out of my windshield washer fluid reservoir. This has the following benefits:
1) Reservoir is already there and holds > 1 gallon
2) Maintain use of Windshield washers because fluid is dual purpose
3) Less aggressive fluid (Straight Methanol can be hard on soft seals vs 50/50 mix)
4) Washer fluid low light pops up on dash when fluid is low. This acts as an alert to driver and helps prevent driver from running out of fluid without know it
5) No need to buy separate fluids and mix, less hassle, more consistent mix if you buy the same kind/brand/rating.
6) Readily available at gas stations instead of special order.
7) Costs less per gallon, generally,
8) Some believe that the latent heat of water, coupled with methanol, has synergistic benefits. Methanol = lower IAT, Water = Antiknock. Together =
9) Using the 50/50 mix will hold up to winters without freezing and will not evaporate in the summer as fast, which will maintain a more consistent mix ratio.
10) 50/50 mix is much less of a fire hazard than 100% meth.
Some swear by 100%, some swear by 50%, some swear by blue stuff. As long as your IATs are down, AFR is correct, and there's no knock/det, you'll be ok and make good power with the addition of a Meth/water system.
Hope this helps.
HRHohio, I know people have used the WW fluid before, and I don't have physical proof that it does anythingng harmfull, but I can't get over the fact its f-ing blue WW fluid and was not formulated with the purpose of being injected into your motor.
As for the price, I bought 5 gallons of meth a couple years ago. It cost me $20. I mixed it with distilled water that was less than .50¢ a gallon. So essentially I have 10 gallons of the mix for about $22.50. That 10 gallons at the rate I use it (and I beat on my car a LOT) will last me about 4 years. So yearly I spend a little over $5. To me, that is well worth knowing I am running something I know to be 100% safe and meant to be injected into my motor.
