Dual meth nozzle placement
Old Oct 17, 2013 | 11:21 AM
  #81
Forcefed86's Avatar
Originally Posted by Ford_Assassin
Spraying pre turbo has my interest, except I worry about the BOV allowing vaporized meth out when letting off the throttle too. I wouldn't want an invisible fireball running through my engine compartment. I guess I would just need to be careful of its placement....
If you use a small enough nozzle pre-turbo it should technically all “flash” before it hits the BOV. You would just need to run a large nozzle post BOV as well.
Few buick guys running two kits. One with small nozzles and straight water or washer fluid for pre-turbo. Then 100% meth at the throttle body with big nozzles.
