What tires are you high HP guys running on the street? 800-1000rwhp
Old 07-16-2013, 11:52 PM
jt76's Avatar
Default What tires are you high HP guys running on the street? 800-1000rwhp
As title states.. I asked a similar question in wheels and tires but i figured i would get more applicable/first hand answers here.
My T/A is twin turbo , 6 speed and a stock width 9". Around here, people mostly roll race. I would also enjoy the occasional trip to the track. I currently have nitto 555R's on my 17" fikse's needless to say traction is non existent. The car makes 803rwhp on 12psi and i would assume I can make 900+ on high boost. I have a set of 15x10 race stars that i want to put some beefy radials on (sidewall!) What would you guys get? What size etc? Im thinking hoosier or M/T radials.. what say you??
Old 07-16-2013, 11:56 PM
Detoxx03's Avatar
On my trans am I would run et streets. On the vette I run NT05R's.
Old 07-17-2013, 12:15 AM
itsslow98's Avatar
Im not that high hp wise but I can dead hook with 18" mickey thompson et street II's brake boosting from 40mph. Easing into it in 1st also has no wheelspin. By far couldnt imagine any tire hooking better on my setup.
Old 07-17-2013, 12:26 AM
9 Second Truck Club
stock48's Avatar
I have Gen 1 micky 275's on my Nova and I can get into it all by 60mph sometimes. Can stick at 40 mph if I leave it in hi gear. Also have some 30x9 slicks and they are pretty much hopless at any speed on the street.
Old 07-17-2013, 12:30 AM
Brian Hoss's Avatar
Michelin Pilots or Nitto drag radials. 335/30R18 rears. Pilots up front.
Old 07-17-2013, 12:33 AM
jt76's Avatar
Yeah i currently have 27X11.5 hoosier slicks on the race stars right now... they look the part but are useless on the street
Old 07-17-2013, 12:59 AM
9 Second Truck Club
stock48's Avatar
The Gen 1 mickys seem to be the best I have found for a small tire. The M$H might work decent haven't tried them yet. Front shock extension need to be loose, and compression tight for street.
Old 07-17-2013, 06:24 AM
skinnies's Avatar
Here's what I've ran on my mustang....
Mt pros are horrible on the street
28x10.5w mt drags work GREAT
275/60 futura pep boys tires work quite well, but I have a good boost controller and I've been 9.5's on these tires at the track
If you are killing a set of good tires, look at the tuneup, timing/boost adjustments can make a huge difference.
Also I did like the hoosier qtp's on the street on other cars, the hoosier slicks was real hit or miss. I've ran the old mt pros in the 235/60 and 255/60 size and they worked pretty good on my ltd.
Old 07-17-2013, 08:15 AM
Preston99WS6's Avatar
MT 325/50 r15 ET Street on weld prostars on mine. Trans Am rear quarters are 3/4" wider than a camaro and these will fit in the stock wheel well and be able to tuck into the body. You will have to massage the foward lower section of the inner fender though. I used a torch and body hammers so its was done nice and smooth then sprayed under coating back on the massaged area, you can tell anything was done to it. A 315 should fit without anything having to be done. My car will dead hook from a 5 mph roll on and stay planted on all the shifts.
Old 07-17-2013, 09:32 AM
Ryans99ls1's Avatar
Im a lil under 800 but my mickey e.t. streets (255/50/16) hook in anything other than 1st. Even in first, im not lighting them up but they are are spinning somewhat. I cant see any other tire working this well on the street. They are gonna be done soon but its really nice knowing i can race at any time and not worry about traction.
And like someone said above, i have my front shocks set pretty loose(single adj. unfortunately) and i dont have front sway bar so it plants the rear tires pretty well.
Old 07-17-2013, 09:57 AM
Guard dog's Avatar
295/17 MTs on weld RTS
What tires are you high HP guys running on the street? 800-1000rwhp-image.jpg
Old 07-17-2013, 10:19 AM
willizm's Avatar
I run MT ET streets on my 17" TTM's. They are ok on the street, but I will spin the crap out of them at anything lower than 60mph.
Old 07-17-2013, 11:05 AM
Tirefire's Avatar
Off topic: can you show us some pics of your Fiske wheels. What are the specs for the rear (ie backspacing). Show some rear shots to see how much they stick out. Been wanting.to get some wheels for my ws6 but ta's are hard to match with nice wheels and yours looks baddass!!
Old 07-17-2013, 11:08 AM
MaxxMitchell's Avatar
MT ET street 325/50/15 is my normal tire of choice.
Hoosier 28 11.50 slicks where horrible for street action only
Hoosier 275/60/15 drag radials work great, but expect only 1-2 weekends of heavy street racing before the fade away well before tread is to wear bars
Nitto 275/50/15 actually did pretty well for roll racing
Mickey Thompson Sportsman S/T Radial Tires 6030 - mud/snow tires, do decent from a roll 9.9 at the track on them.
Timing and boost control are the biggest thing about making any tire work in any condition
Old 07-17-2013, 11:16 AM
NoGo's Avatar
If you don't want to die in the rain Toyo R888. IMO as good as the Nitto, but less than the MT.
If you never drive in the rain the MT.
Old 07-17-2013, 11:47 AM
Twotonefreak's Avatar
I run M/T ET street II's 345/35/18's on my vette. I don't do any dig runs. They were awesome when I was on the YSi and making 1K. They'll spin to hell and back from a 60ish roll with the F2 now...
I had to drive home in an insane down pour last night, **** was all over the road even trying to be careful as I could be....
Old 07-17-2013, 12:29 PM
jt76's Avatar
This car NEVER sees rain..maybe 2-3 times in the 5 years i have owned it so that is not really an issue... Tirefire, i will try to take a couple pics for you this evening.
Old 07-17-2013, 12:46 PM
Tirefire's Avatar
Thanks bro!! I'm sure I'll be coming back to this thread, I'm curently tuning my 390 with F1a. Thanks again...
Old 07-17-2013, 02:03 PM
necrocannibal's Avatar
I run around on Hoosiers and they really don't hook on my twin turbo car. Forget the plate it is from a previous owner.
Old 07-17-2013, 02:13 PM
Isolde's Avatar
Around here the hot ticket is 345/40R17 drag radials from Toyo
Quick Reply: What tires are you high HP guys running on the street? 800-1000rwhp
