FI heads
Old Jul 18, 2013 | 07:04 PM
DemonicZ's Avatar
Default FI heads
probably see 8-10 lbs of boost at most, will stock worked heads be fine or aftermarket?
stock block
stock internals
140k miles
1 7/8 long tubes
CME
FTP lid
02 10 bolt
rebuilt 4L60E with 3000 converter
Old Jul 18, 2013 | 07:40 PM
allout06's Avatar
i wouldnt even bother touching the heads
Old Jul 18, 2013 | 07:45 PM
F110Mech's Avatar
i wouldve done a search and seen that people are pushing 800+ hp through stock heads...
yes, stock heads are fine
Old Jul 18, 2013 | 08:06 PM
Blackpanther99's Avatar
Oh heck yeah, stock heads will be more than fine.
Old Jul 18, 2013 | 08:17 PM
allout06's Avatar
you stock heads will make more power than the bottom can handle.
Old Jul 18, 2013 | 08:24 PM
GarrettM's Avatar
Check out mr2liter's post. We just made over 700 on his with an f1r on a stock bottem end and the heads have never been off of it. Was about 15#s on e85.
Old Jul 19, 2013 | 08:02 AM
Old Geezer's Avatar
Lightbulb The weak link[s]....
Don't worry w/ the bottom end. The trans and rear will give up B4 the crank/rods do..
Old Jul 19, 2013 | 10:15 AM
allout06's Avatar
lol...true story
Old Jul 19, 2013 | 12:44 PM
Huron Speed's Avatar
LS1Tech Sponsor
the stock heads will be fine for that low boost level. IF you decide you want to step it up some, alot of guys run 317's
on my personal car, i plan to try out a set of LSA heads.
-Casey
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
Check us out on Facebook at: www.facebook.com/HuronSpeed
TWITTER @HURONSPEED
Old Jul 19, 2013 | 02:34 PM
Troy5061's Avatar
I run stock 317s at 10.5psi and its fine, a buddy ran Livernois cnc'd 243s at almost 20psi. Like these guys said the motor will be fine but will make more than that transmission and rear end want. The 3-4 clutches in my 4l60e hate my turbo.
Old Jul 19, 2013 | 03:21 PM
11SECSS's Avatar
What about running a set of stock 243's.
