procharger problems
Old Jul 23, 2013 | 02:06 PM
zayne0's Avatar
Default procharger problems
My friend is having issued with his procharger and is to the point he just wants to sell it dirt cheap. It definitely sounds like a tuning problem. One day it runs strong the next day it falls on it face he says. Anyone have similar issues with their procharger? He says it has been tuned by multiple ppl and they all said it was the supercharger giving problems. I say bs.
Old Jul 23, 2013 | 03:08 PM
conan's Avatar
Belt slip, bypass valve no closing all the way, boost leak...
I would look over everything and make sure there isn't a mechanical problem first and then question the tuner as to why he thinks its the prochargers problem.
Old Jul 23, 2013 | 03:30 PM
camarochvy21's Avatar
Tell him to stick with it. Check for boost leaks and like conan said, check the mechanical s. Mine should be producing around 10lbs but im only seeing around 4. Tighten everything up and was good to go. But now every time i get on it, the crank bolt loosens, so now i dont know what is going on
Old Jul 23, 2013 | 06:08 PM
I8UR4RD's Avatar
if he is not willing to check anything or attempt to fix it, then he prob should get rid of it. Maintenance and boost go together like peas and carrots.
Old Jul 23, 2013 | 07:42 PM
zayne0's Avatar
He can't answer half the questions I have so I'm on my own, he can't answer if it was sd or maf cl. If he did a crank pin, if they checked the ic tubing....
Old Jul 23, 2013 | 08:11 PM
I8UR4RD's Avatar
a good tuner is above all else a great diagnostic technician. Need to take it to someone reputable who can log it and tell exactly why the damn thing is studdering. could be as simple as a sensor. could be something else. good luck.
Old Jul 23, 2013 | 08:42 PM
Blackpanther99's Avatar
Agreed^ Its a must.
Old Jul 23, 2013 | 09:52 PM
6D9 Matt's Avatar
Ding ding ding
Old Jul 23, 2013 | 10:39 PM
zayne0's Avatar
Looks like I'm about to be the owner of a procharger.... Now what to put it on....
Old Jul 24, 2013 | 08:30 PM
Pwebbz28's Avatar
You need to key the crank pulley.
Old Jul 25, 2013 | 08:51 AM
What do you own?
Old Jul 25, 2013 | 09:12 AM
I am, bought a new crank bolt from bob, just might have to pin the crank pulley, but im not sure how to go about it. Can I pin the 6 rib crank?
Old Jul 25, 2013 | 02:47 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Yes you can, I'll e-mail you a copy of the installation instructions here in a few minutes. Thanks, Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jul 25, 2013 | 02:59 PM
thanks bob!
