76mm street Nova runs 8.39/163.75 mph!
#87
#88
CR is around 9;5-9;7, Its got stock 317 heads, with hand port job from me. 408ci LQ9. 239/247 cam at 624 lift, GT91 108AR. I was thinking my KR sensors stop working, but they pickup me banging on the exhaust! Just need to know im not hurting the engine. Wish I could see a timing table to compare mine with. Its in a 1981 TTA,4L80E 3600 stall, 3.08 gears, car weigh 4000lbs.
#94
Stock48 I see you went back to Famoso and got it to run good. I am the one with the Burnt orange 67 Camaro in Limited 10.5 that ran 5.28@133.74mph that you came over and talking with. I was telling you my son wants to do his 70 Nova just like yours too. Keep up the good work.
MIke
MIke
#96
MIke
MIke
#98
He's running complete stock bottom with the newer stock rod, new stock rings gapped at 0.022 with arp head studs, 218/218/112 .570 cam
8.5 10 blt, 3.23, spool, and probably 33 spline and the original 275/60 MT radial, full cal tracs setup
Holley HP Efi, 2000cc FIC's, 4303 magnafuel, PG w 1.76, SC3000 or PY3400
From what I've read, the early rod will bend at 100hp less than this power level. Calcs put him at 1000+.
I've got a nova so I'm keeping close track on J's antics.
