Stock Rockers or Trunion Upgrade?
My engine is almost complete forged rods, pistons, stock crank, Texas Speed .650 dual valve springs, Custom Tick Cam .598/610 lift cam. I think I will be fine to just clean up a used set of rockers with brake cleaner and soak in oil. I am contemplating the trunion upgrade but from searching it seems many have had issues with the trunion not moving as freely after install. Dont feel like spending $400 on new rockers. I would think with the relatively low lift of my cam and .650 valve springs and 150lbs of seat pressure I should be fine with a used set of stock rockers but want some other opinions.
I have had a trunion break on stock rocker before but I think when my springs were swapped they didnt set them up properly. Because of that I am stuck on what to do because I would think a trunion up grade can still break.
Yeah, I just had heard that several people saying once they were installed they did not move as freely. That worried me. I guess I havent heard of anyone having it break after the upgrade.
The following users liked this post:
Homer_Simpson (02-26-2023)
Do it! Do it! Do it! to me it is cheap insurance! i would do the trunion upgrade over aftermarket rockers... seems everyone is always having issues with aftermarket rockers and they are super expensive!
if you dont have rockers yet brian tooley sells the factory rockers with the upgrade already for 270 IIRC.
The following 2 users liked this post by Nitroused383:
joyridin' (10-12-2020), The BallSS (10-12-2020)
I've considered epoxying in some screens over the drain back holes in case of failure but they just don't seem to fail without some other interference issue.
The stock ones have failed, I have fished out the needles from the oil pan with a mag. How rare is it I dont know, prob a pretty low failure rate though. I have only used the Summit trunnion upgrade, the stock bolts are tight in them, had to burnish the bolts to get them loose, so they wouldnt affect the torque. The new build is getting stock ones, since I prob have 50 to choose from, lol.
Yea I know this is a 2013 thread... but it was a good one!
We use to epoxy screen over drain back holes on the turbo Buicks for this reason. I'm thinking a well placed small neo magnet could be used as well. FWIW I've run a ton of different used factory rockers and never had a failure. but I've seen pictures and heard the horror stories as well.
I've heard if you run 400lbs or more on the open spring rating, its best to run the bushing style.
