need 40more hp, 35shot or more boost?
i spray out of the hole for 1 sec to get me moving and figure i can up the shot out of the hole from a 75 to at least a 100 and maybe 125, that should get me .1 on my 60's i think.
i can pull 150lbs off of the truck, that should be .1
now i need more power, the truck is prety much set up for a 2 stage wet from before i had the turbo so the question is which would be better, safer or most likely to get me my 10.99? a 35shot the entire run or 2-3psi more boost? i will still be spraying the bigger shot out of the hole either way i go.
i am at about 13psi now and am using 111leaded gas,
)i dont think the turbo is maxed or the intercooler, nothing like that, my iat's are still prety cool. i am only spraying for the first 1sec in case anyone missed that before, no way to dyno that since i don't spray up top.
my maf is maxed though, upping the boost will mean fueling with the pe vs rpm table, thats not really a problem and i run a wideband at the track.
they were the cheaper felpro gaskets and i may have been slighly lean. now i have better gaskets, slightly more torque on the studs, running 11.8 for the leanest part of my a/f ratio and 11.5 for most of it.
who knows i might just pop another gasket, or worse
, probably not the brightest thing to try and run a 10 with a prety much stock motor. I think you need a 1.5 to run a 10 second pass unless you try to run a 1.6 with a whole lotta power.
even if i only spray a 35shot(the entire run) you think i should drop the timing?
Chris
15 degrees would be far safer and should go a long way to keeping the heads on the car.
I would spray off the line assuming you only spray above 3500 rpms. The ET is all about the first half of the pass (like Chris said).
