How cheap to hit 8s?
Old Aug 14, 2013 | 10:37 PM
67maro's Avatar
To run E85 with a big enough pump to make you go 8's you would probably be 2-3k deep alone in a fuel system.
Old Aug 14, 2013 | 10:40 PM
00MaroonZ28's Avatar
Not to mention the turbo, inner cooler, wastegate, and all the other supporting stuff needed.
Old Aug 14, 2013 | 10:49 PM
a4ls2goat's Avatar
Do some reasearch.
Theirs a nova here running 8.3s on a stock 6.0.
I would say about 10-12k $ not including the price of the car.
Old Aug 14, 2013 | 11:05 PM
F110Mech's Avatar
Originally Posted by 00MaroonZ28
Then why waste your money on this build and focus on your other build?
Am I the only one that does things to see if they can be done? Isn't that how we got to the level that we did with the gen 3 platform?
Old Aug 14, 2013 | 11:07 PM
F110Mech's Avatar
These are the obstacles that I'm looking for. Now what's the least expensive way to get it done? Just so were clear, just because I'm looking to see how inexpensive things can be done doesn't mean that its going to be a hack job.
Old Aug 14, 2013 | 11:30 PM
stoverz28's Avatar
Maybe if you're in a full weight f-body or vette...
Old Aug 15, 2013 | 12:31 AM
jt76's Avatar
As far as the HP is concerned.. my friend ran a 9.00 @ 153... so a good poop away from an 8.99 with 770rwhp through a th400 in a 3700lb Camaro, the new owner dipped deep into the 8's with the same setup... but as has been said there is a lot more to it (as an 8.99 is my ultimate goal, I am figuring this out very quickly, making the HP is the easy part)
Old Aug 15, 2013 | 02:04 AM
360demonRT's Avatar
All these "20k in the motor alone" etc etc haven't read many of the stock shortblock threads on here. A damn shoebox s10 is LIGHT! A 5.3, s480 for cheap from forced inductions, jgs gate and bov, **** on an intercooler, it's drag only on corn. A th400 with good converter and a cheap rebuild would probably hit the mark. 5k? Maybe, especially if your doing all the work. Guy doesn't want an erl superdeck with twin gtxxx turbos, a sunshell or whatever glide and a Moser 9"
Old Aug 15, 2013 | 04:59 AM
Blackpanther99's Avatar
This is gonna be interesting
Old Aug 15, 2013 | 05:17 AM
Camaro9969's Avatar
I can't believe you started this thread. Lol
Like I said man the money your going to spend on that ratty *** truck just use for the Camaro because with any build there will be set backs and trust me you WILL need some extra cash for it.
But can it be done for cheap? Yes. But why? 5-8k to prove a point seems crazy to me.
Old Aug 15, 2013 | 05:40 AM
gtfodave's Avatar
can be done, yes I wouldnt be in the car for a testdrive.
Old Aug 15, 2013 | 05:50 AM
  #32
F110Mech's Avatar
Haha the camaro will get done, this is for fun/learning. I'm curious as to what people can come up with to get it done.
Old Aug 15, 2013 | 07:12 AM
  #33
1fast bird's Avatar
I would not push a stock block to the 8's without a cage and all the safety gear. You are driving a ticking time bomb when coaxing that kind of power out of it. When it blows and you drive through your own oil, it's pretty much a done deal that you will crash. That alone will cost you a pretty penny.... You will need a trans with a t-brake for sure to even think of running in the 8's, paired with a good turbo converter.... the list goes on as to what you will need to go that fast. The little things as you probably already know, add up super fast.
I'm putting together an s10 with a 5.3 now (collecting parts anyway) and I'm on a budget. Without the truck, trans, converter and turbo added into the cost, I'm struggling to keep my build under $5000. I'm not looking to go 8's by any means either.....
Old Aug 15, 2013 | 07:59 AM
  #34
edwardzracing's Avatar
My thoughts are that there is a reason there are so many good running "JY" turbo builds... they really are friendly on the budget. If it were "cheap" to run 8's, it'd have been done a lot more often by now. I'm in agreement with 1fast bird... if you're going to try and make that sort of number without all the safety goodies (which I imagine will be at least $1000 in itself), then you're nuts. And I could only hope that nothing goes wrong at 140+ MPH that might result in killing someone. I understand we all want to go fast on the cheap... but skimping out on keeping yourself safe and, yes even the guy in the other lane, just doesn't seem wise to me.
I would guess "No" on getting it done for under 5 grand.
Old Aug 15, 2013 | 08:05 AM
  #35
F110Mech's Avatar
Thanks for the insight. Safety equipment would be in place but not included in the budget. I do have a good th400 converter already so that would be a freebee. in your experience, how difficult is it to get an s10 to hook at 800+rwhp? I've never built a drag truck (or anything this light) so I have no idea on that one. Part of the idea would be to make it barebones to get it las light as possible. There would be a full cage in the truck as well as a chute. Understand what can happen with a crash at those speeds and that a stock block(let alone a stock bottom end) would be on borrowed time at this level. I would like to get the tru k going on a lower horsepower level and 8.xx be my end goal without buying twice. This will be done all on used parts also to help with the budget
Old Aug 15, 2013 | 08:14 AM
  #36
F110Mech's Avatar
I posted as you were posting about the safety equipment. I'm hoping the the lack of desire to keep it streetable allows me to make it light enough to hit the number eventually with much less horsepower than what an fbody would require.
Just like when I ride my street bike, there is always a risk involved. Obviously I will take safety precautions, just as I do when I ride
Old Aug 15, 2013 | 08:28 AM
  #37
67maro's Avatar
In fear of running out of pump I would pick up an Aeromotive eliminator which buy itself is 620. We haven't even got into injectors, tank assembly, or fuel lines. A cage in an 8 second car with a questionable chassis is not something I would skimp on.
Old Aug 15, 2013 | 08:34 AM
  #38
Hopeless cause. He's not gonna listen.
Old Aug 15, 2013 | 08:42 AM
  #39
Black98s10's Avatar
I'd talk to Silver_82, he put his dime in the 8's on a TT stock 5.3L. Stock frame rails, and homemade caltracs
Old Aug 15, 2013 | 08:58 AM
  #40
Grr's Avatar
Grr
Not including safety gear, the price of the truck and using what you have it CAN be done for around 6k
5.3
Vic jr
Blow through carb and dual walbros
S475
No inter cooler or bov
8.8 caltracs bars
Th400
Megasquirt for the spark
A box of hole saws and a good 1/2" drill
You will need to be around 2800-2900# with driver and run the s475 up at 18-20#
