Remote Single/Twin Supercharger setup
Idea is a stock displacement 4.8/5.3 built to be as bullet proof as possible. Then remotely putting 2 gt500 superchargers. Brand new off ebay a single one can be had for 900 thats oem m122 eaton unit.
I figure it would produce more boost then I would ever need while having zero boost lag, cost would be around the same or less than your normal s/c setups, and of course extremely unique.
I can fab the brackets, and tubing, and It would be a fun project for the wife and I to work on.
I have seen the thread of the single being done on a 3rd gen. I guess beyond space and the crank pulley what else should be taken into account that might not be obvious?
I was going to tube the compressed air into a fast 102mm intake, however a ported ls6 intake I have been told would work fine too. Was considering a intercooler however this would not be a daily driver so might only mount one instead of two. I guess im looking for some brainstorming help.
hood would be custom fab'd or a big ole cowl of course maybe try to retain the shaker hood and attach the s/c's air intakes into a custom made shaker piece.
found this while looking for info:
http://www.alabamaracingscene.net/fo...ad.php?t=57767
its an m90 under the hood of a 4th gen.
I however am seeing all the tvs2300 units going for 6K+ part of the project was to be different while keeping costs down.
edit:
Also I have yet to find out if a remote mount setup is as efficient as if it was mounted as originally intended. I would assume the system wouldnt know the difference and I would just have to make sure the system is mounted in the most ideal spot.
http://www.ebay.com/itm/2013-2104-Mustang-Shelby-SVT-GT500-OEM-5-8L-Supercharger-Blower-Kit-/231037610905?pt=Motors_Car_Truck_Parts_Accessories&hash=item35caea2b99&vxp=mtr
2013 2014 Mustang Shelby SVT GT500 OEM 5 8L Supercharger Blower KIT | eBay
I guess ill have to look harder and keep my eyes peeled. How much psi would a tvs2300 make over a m122? I cant seem to find that I also cant seem to find how much an m122 makes.
Edit
I have found that with the stock ford motor it makes 450-500 rwhp, more can be gained with a aftermarket pulley and porting the setup. I think that a 4.8/5.3 motor displacement is close to the stock ford motor 5.4/5.8 used with these from the factory.
I think the best intake would probably be a custom sheetmetal one to maximize flow
I am primarily looking at using a remote mount supercharger because its alot less expensive than a real ls1 supercharger.
Also Im looking at a supercharger over a turbo as the car probably wouldnt be driven daily, it would be driven on the streets probably more than anything. I have liked the supercharged cars ive had over the turbo'd ones. While both were fun I just liked the always at hand fun and no lag. Just push the pedal and go.
Edit:
I have found that m122 max safe and reliable boost levels seems to be around 22psi. This is gotten from several mustang forums so I suppose hear say lol. Now the real question is can i run two m122's at 14ish psi to get around 20 psi total? I assume two running at 10psi wont make exactly 20psi but maybe im wrong. Again I may be wrong too and that running two at 14psi would only yield a *** ton of 14psi air.
I also would be interested in if the pulley shaft can be flipped thus allowing them to mirror eachother(a very visual only mod)
UNFORTUNATELY I have spent alittle more time looking up about the gains from twin supercharging, and its nothing. Everything I read labels it all show and no go. Infact it would perform worse and overall make my life simply harder, more expensive and slower. So a single remote supercharger itll probably be. However Hopefully by the time I get the 78 ready for the build a tvs2300 will be around the cost of a m122 now.
A M122 that can put me into the 500rwhp range is roughly 900 new and 400 used id maybe need a throttlebody 50 used 300 for single blade, thats most expensive in parts its 1200 and ill just have to buy bracket pieces and tubing, along with a belt and a supercharger pulley maybe 400.
so im looking at $2300 total for easily 500rwhp and a very unique setup. Im honestly thinking of relocating my coil packs and placing one ontop my ls1. I already have a supercharger crank pulley and id just cut my hood. Mad max style.
edit: the more I research the more i want to buy a junk hood and slap on ontop my ls1 and just cut the hood for clearance. I have a supercharger tune saved for my car as it used to have a procharger. Run it around 9psi heck id bet atleast 150rwhp increase for about 1600 bucks if I went full ghetto retard with it.
I think with a custom intake and singleblade intake on my car with the mods I have I could easily blow apart my stock rearend......lol
I would also sugest looking at the 1990s Aston Martin Vantage for insperation. Aston used two m90 units I think that were mounted off the heads with a a air to water chargecooler.
