Watergate help
Old Aug 28, 2013 | 04:04 PM
Hulkls1's Avatar
Default Watergate help
I have a tial sport 38mm wastegate for my 5.3 build I have a gt45 turbo is the big enough wastegate ?
Old Aug 28, 2013 | 04:11 PM
enroh's Avatar
It will work but may cause boost fluctuatuion. A 50mm would be better, that is what i run with my gt45..
Old Aug 28, 2013 | 04:43 PM
68 SS's Avatar
^ What he said, really the biggest you can fit will be best and allow you to control boost better down low.
Watergate is over by the way oh and Nixion resigned...LOL
Old Aug 28, 2013 | 07:37 PM
Hulkls1's Avatar
Any brand ?
Old Aug 28, 2013 | 07:45 PM
Camaro9969's Avatar
Originally Posted by Hulkls1
Any brand ?
Tial, JGS, Precision all good. I like Tial best but that's just my opinion
Old Aug 28, 2013 | 08:01 PM
1fast bird's Avatar
Wastegate placement is almost as important as the size.....
Old Aug 28, 2013 | 08:11 PM
Fast86z's Avatar
I run an ebay EMUSA 38mm tial knock off on my 4.8 with GT45 turbo. Boost does not fluxuate even down to 3-4 psi it works great. Is it ideal? Hell if I know but it works, just run it dude!
Old Aug 28, 2013 | 09:01 PM
Hulkls1's Avatar
I put mine right where the two pipes come together
Old Aug 28, 2013 | 09:45 PM
enroh's Avatar
Yeah that's where my wastegate runs off, the flange where they join. I run a turbosmart 50mm progate, no surge or creep from that baby!
Old Aug 28, 2013 | 10:17 PM
NightmareTA's Avatar
Buddy of mine ran a 38mm gate with an ebay GT45 at around 7 PSI and it worked fine. Not to say this will be the outcome on all setups, but if you place it correctly, it should work ok. I went with a 50mm on mine for peace of mind.
Old Aug 29, 2013 | 06:06 AM
Hulkls1's Avatar
I'm going to try it for now but I do want to turn it up to 15-18 pounds my goal is 650-750 rear wheel hp
Old Aug 29, 2013 | 10:42 AM
Preston99WS6's Avatar
You will be fine, I have run a Tial sport 38mm on a 6.0 with S480 down to 7psi with no boost spikes/deviations. As stated above placement is just as important as size.
Old Aug 29, 2013 | 10:56 AM
1fast bird's Avatar
That's important too but, I mean have the wastegate plumbed with the direction of exhaust flow. Having it at a 90* angle to flow will not work as well as one placed at 45*.
Old Aug 29, 2013 | 12:57 PM
Hulkls1's Avatar
Mine is about 20* damn near straight up
