750 csu blow thru bog help
Old Aug 30, 2013 | 11:10 PM
huggerorange69's Avatar
Default 750 csu blow thru bog help
I have a 03 4.8 lsx, ls6 cam, 76mm turbo. csu 750cfm carb. 32 deg timing with a map sensor pulling it down to 20* at full boost. 72/78 jets. Regular power valve in the front and a boost reference power valve in the rear. I do have jet extensions. 7 psi fuel pressure that rises 1:1 with boost. My problem is when I'm doing a burnout the car does good for about 2sec then while the tires are spinning it wants to cut out and die. When I re start it it blows Black smoke everywhere and wants to miss and carry on till I clean it out a few times. Next I bring it up to line footbraking building about 2-3 pounds and when I leave it goes nowhere, best 60ft is 2.04 it's just bogging down, then at about the 330 it comes into boost and hauls ***. Ran a 8.02@102 in the 1/8 and 11.97@125 in the 1/4. Where do I need to start to fix the bog and get it to leave so I can get a good et not just mph.? Thanks.
Old Aug 31, 2013 | 08:02 AM
knuts82's Avatar
Do you have and A/F gauge? What front power valve are you running. Also try more timing..
Old Aug 31, 2013 | 04:30 PM
wild1100's Avatar
How full are the bowls do you have sight glasses?
Old Aug 31, 2013 | 07:06 PM
knuts82's Avatar
That was my next thought. Bowls going empty possibly.
Old Aug 31, 2013 | 07:15 PM
Floats are in the middle of the sight glasses
Old Aug 31, 2013 | 07:16 PM
I'm going to break down and get a wideband with a data logger so I know exactly what it's doing
Old Sep 1, 2013 | 11:21 PM
wild1100's Avatar
Call Kevin at CSU its his carb. Was it built for that combo.
Old Sep 2, 2013 | 08:58 AM
3pedals's Avatar
i think your fuel pressure is too high, might be pushing fuel past the needle/seat. try lowering it to 5.5psi
