Input on my boost control issue
Old Sep 4, 2013 | 02:52 PM
357i's Avatar
Default Input on my boost control issue
To bring you up to speed, I'm running a mostly stock LS1 with a TC78. The entire setup was made by me to fit the tight constraints of a BMW engine bay.
Here are a few pics of the setups progression
Made a plan for the wastegate:
Wastegate is a PTE 46mm. I really thought this setup would work great. It does not. I have a 7lb spring in it with no boost controller. The wastegate is an open dump and the car has a full 3" exhaust. The gate opens right at 7.5-8psi. It will hold 8-9 psi in 1'st gear, about 11psi in 2nd gear and 16 in 3rd gear. I havent run it at all in forth gear, but I can imagine that it will continue to climb. I guess this winter I will pull it back apart and try something else. Tight spaces will not allow me to run a wastegate right out of the side of the collector. Any other ideas?
Old Sep 4, 2013 | 03:06 PM
Forcefed86's Avatar
How much room do you have on the pass side? Can you add another gate to that side? If you went to a larger turbine housing it would be easier to control the boost as well. What is on there now?
Old Sep 4, 2013 | 03:07 PM
turbocamaro125's Avatar
It looks like that setup should work good. what exhaust housing? .96 t4? I wouldn't think back pressure at that low boost would cause that...I had a single 44mm tial gate welded 90* off of the merge with a cammed ls1 and a t6 s480 and it would hold right a 9lbs with a 8lb spring.....idk try adding another 46mm gate.
Old Sep 4, 2013 | 03:16 PM
Camaro9969's Avatar
Can you post pictures with everything in?
Old Sep 4, 2013 | 03:25 PM
357i's Avatar
it is a .96 AR T4.
Adding a second gate will be tight. I feel like the single should be more than enough if set up correctly.
Here is the whole package
Old Sep 4, 2013 | 04:22 PM
357i's Avatar
was considering coming off the back of it like this:
or i may have room to do something like this:
Old Sep 4, 2013 | 05:25 PM
stevieturbo's Avatar
Cant see in the picture, But how have you the w/g signal line plumbed ?
For low boost you should be blowing boost directly into the bottom port only.
Old Sep 4, 2013 | 08:39 PM
357i's Avatar
Line straight from manifold to bottom port only.
Old Sep 5, 2013 | 01:02 AM
redss82's Avatar
you have the wastegate plumbed from the intake manifold? if so try running it straight off the compressor
Old Sep 5, 2013 | 07:20 AM
357i's Avatar
Yea, that was my mistake, I was thinking about the hose I ran to the BOV. The wastegate is hooked to a fitting coming out of the turbo outlet.
