Stock Bottom 4.8L w/88mm (Not a Typo)
Old 09-25-2013, 07:55 AM
  #41
HydroStream6's Avatar
This is very encouraging!
I'll be taking my 4.8 truck to the track Friday. It has stock heads, LS6 cam, good springs, LS9 gaskets, head studs, E85 and a BW S372. I'm @ 15psi right now, no idea how much power or how fast it is. It's so hard to gauge how quick it is because it's in a truck haha. 4850lbs empty. I'm going to run it on 15psi and then go up from there. I'd like a 10s pass in it.
Old 09-26-2013, 11:50 AM
  #42
sixt5's Avatar
all you gotta do is throw a hitch on that thing and tow a boat to beat foose04! haha
congrats on the numbers! what kind of compression should this motor be? im gonna be real close to 11:1 (maybe 10.8 or so?) and im kinda scared to be throwing a lot of boost to my 6.0. lucking going to be running e85
Old 09-28-2013, 10:44 AM
  #43
Z06_Fan's Avatar
Very nice! Ha, you might not even go back to the 408......
If you're running the 1.23 housing, get a 1.08 and crank it up some more on that 4.8......oh and I'm sure you're running 2.5" mid pipes/crossovers which doesn't help the spooling
Old 09-29-2013, 02:06 AM
  #44
n20z28's Avatar
What plugs are u running?
Old 09-29-2013, 03:50 AM
  #45
Kingc8r's Avatar
I wish I had the fab skills for this. I love seeing 4.8s and 5.3s put in work.
Old 09-29-2013, 08:59 PM
  #46
nahasapeemapetalon's Avatar
Saturday got rained out but I got to race today.
While checking the car over during tech I looked underneath and noticed this...
Over time and vibration the fuel solenoid nut worked its way off, the coil rubbed on the ground a little and the spring was gone. So I cut it off and tried adjust the tune enough to compensate for the dry N2O shot. I was going to run 150shot but reduced to 100shot to try it and log it first. So no spraying down the whole track (like my 1060whp dyno).
Pass #1
10.004@146.25
100 shot until 11lbs, 24.7 lbs at 71mph and up
Pass #2
9.92@145
150shot until 11lbs, 24.8lbs at about the same speed
Pass #2 In car vid
http://www.youtube.com/watch?v=eloBy...ature=youtu.be
I wasn't getting the 60' I hoped for but I met my goal of a 9 second pass so I am very happy.
Old 09-29-2013, 09:42 PM
  #47
bonestock_442's Avatar
Nice work bro. Now let the poor thing rest!
Old 09-30-2013, 01:53 PM
  #48
Forcefed86's Avatar
Old 09-30-2013, 11:13 PM
  #49
Pete91's Avatar
Nice I should have my jy pt88/6.0 ready to go in a couple weeks.
Old 10-01-2013, 02:22 PM
  #50
Beatdown Z's Avatar
Not bad for as much as your car ways and how mismatched your combo is.
Old 10-01-2013, 06:55 PM
  #51
yenkomike's Avatar
sweet. hard to change it when you know there is more left with a better 60'.
I'll be happy to run that good with my 6.0 at 3400 lbs.
Old 10-05-2013, 01:35 AM
  #52
BLWN1's Avatar
What's your fuel system and inj? Ba d ***!
Old 10-05-2013, 08:05 AM
  #53
Bosch/Lucas 120lb
Versafueler imp box
Boost-a-pump (single)
Magnafuel MP-4303
Old 10-11-2013, 10:28 AM
  #54
Well i found the limit of the 4.8!
I was out making some vbox pulls yesterday.
Pull #1
5.9seconds 26.xlbs & 100shot towards the end of the run. So so first part of run.
Pull #2 ~27lbs & 100shot
Passenger Side of block by starter
Bolt from motor somehow lodged in caliper and scuffed up my boart wheel.
Bogart Wheel
Old 10-11-2013, 11:21 AM
  #55
yenkomike's Avatar
that sucks but you should be able to find one fairly cheap.
Old 10-11-2013, 01:38 PM
  #56
Mongoose350's Avatar
There's a turbo 4.8 on YouTube that went 9.39 @ 147 in a 280z. Full interior street car. Can't post the link on my phone sorry.
Old 10-11-2013, 02:02 PM
  #57
an den?
Old 10-11-2013, 02:06 PM
  #58
Fast86z's Avatar
Way to go dude!!! What let loose? A rod bolt I imagine. My 4.8 only lasted about a month on 13 psi and 93 only. I'm thinking bad tank of gas and washed bores. In my neck 4.8s run $500-$600.
Old 10-11-2013, 02:37 PM
  #59
jleews6's Avatar
So I guess what your trying to say is ,dont go above 26.5 pounds and 100 shot?
Old 10-12-2013, 04:03 PM
  #60
T/ALT1's Avatar
Nice if you could get the 60' down that setup would have run mid 9's but that still very impressive for under 300ci in a heavy car!
Quick Reply: Stock Bottom 4.8L w/88mm (Not a Typo)
