Help a brother out???
Old May 3, 2004 | 02:36 PM
Noyzee's Avatar
8 second mod
Question Help a brother out???
I have a problem, rev it up snap the clutch, the car lifts, then falls flat on its face for about 150 feet, then pulls back up, and still managed 30 mph in the back half. I raced friday and landed a whooping 2.1 60' with the car totaly dead under me, 96 in the 1/8 and 126 in the 1/4. the car was just stumbling over itself.
Filters clean, new fuel pump going in asap, lines are free, and injectors just redone.
any input?
Old May 3, 2004 | 02:46 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Swap the TPS sensor on the TB.
Old May 3, 2004 | 02:53 PM
Noyzee's Avatar
8 second mod
That is the one thing i havent done, im waiting for my new one to come in. But for some reason i think it is more then that.
But once it is in i will keep my fingers crossed and hope it works!
Old May 3, 2004 | 04:47 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Are you watching the A/F?? On my Supra this happens also when the car has a rich spot, then as boost comes in and leans out, the car hits hard. You may want to check the A/F at that dead spot and see where its at.
Jose
Old May 3, 2004 | 05:10 PM
White_Hawk's Avatar
Jose
That would make sense. If your car goes into PE mode before the boost comes on you could be really rich. If you are brave, get into the PE delay tables that the truck use and make it wait a second before dumping fuel. I wonder if anyone has tried that? I'd try it but my LS1-Edit version doesn't have that function (damn $100 upgrades).
-Geoff
Old May 3, 2004 | 05:34 PM
LS1Tech Co-Founder
I had this problem N/A in 2000 and it was a TPS sensor.
Old May 3, 2004 | 07:34 PM
ws6rufus's Avatar
If it is not the TPS then JZ 97 SS 1500 is probably right. My car was doing the exact same thing as yours and after I got the WB hooked up it showed my A/F was dropping to 9.2:1 when the TPS would first hit 100% and when the motor would get into boost it would lean out and take off like a bat out of hell. I leaned out the PE/RPM table in the areas that were rich prior to boost and it now runs great.
Old May 3, 2004 | 07:41 PM
cablebandit's Avatar
somebody had there battery ground out when it would launch and then it would be ok...maybe look there
Old May 4, 2004 | 06:59 AM
Noyzee's Avatar
8 second mod
I tried the tps, but my fuel pump is out so i havent tried it yet. Im thinking that is my problem, it feels like it is either dumping to much fuel or no fuel. so im starting there.
we shall see soon.
Im also thinking the car might need a better street tune.
Old May 4, 2004 | 07:16 AM
kp's Avatar
kp
A big stumble like that usually means its rich or you have no timing, you have to make sure your PE tables are close at lower rpm beacuse with a 3.73 your rpm is going to drop a whole bunch on a launch if the car hooks up. If you try to delay the PE the car will be way too lean since its the PCM's job to keep the car ay 14.7:1 until it goes into PE. If you have a dead O2 that could cause it to run rich or lean on one bank also.
It could be a lot of other electrical problems, grounds, pinched/burned wiring etc. You really need to log a couple passes and it would be nice t have a wideband in the car. Trying to diagnose a problem like that over the internet is tough, you need a little more data.
Old May 4, 2004 | 07:40 AM
Noyzee's Avatar
8 second mod
Ive gone threw all my grounds, i have checked all wiring, ive replaced plugs, wires, sensors, fuel injectors cleaned, bla bla bla.. It is getting to the point of MURDER!!!! im getting fed up with it.
I do believe however this new problem is rich/lean thing.
my o2's are shut down and have been for some time now, most of last year as well.
but i think once i get my new pump in and the car running again i need a better street tune.
What is the easiest, cheppest, best wide band to put in the car??
Old May 4, 2004 | 08:19 AM
kp's Avatar
kp
plxdeices.com is one, the m-300 is fairly cheap and self contained if you dont need data logging. http://www.innovatemotorsports.com/lm1.php is another. I use a techedge 2.0a but it gets a little pricey unless you build it yourself but it has a built in logger and RPM inputs.
Lot of choices out there..
Old May 4, 2004 | 08:21 AM
Noyzee's Avatar
8 second mod
thanks alot, im going to look into them, i think its time.
Old May 4, 2004 | 08:23 AM
Noyzee's Avatar
8 second mod
tell me something, do i need a labtop, or does that have its own screen?
im not to good with the labtop stuff.
Old May 4, 2004 | 08:29 AM
kp's Avatar
kp
I use mine most of the time going through the a/c pressure sensor and using efilive so I really dont need the rpm and seperate inputs this techedge has. If you dont have atap or efilive the plx with the wireless data logger (if you have a laptop) looks pretty cool..
Old May 4, 2004 | 08:35 AM
kp's Avatar
kp
If you dont have a laptop the m300 will work. Remember its hard to look at at the track while you are trying to drive sometimes but the m-300 has 0-1 and 0-5v outputs so you can use it with efilive down the road if you want to. The innovative one looks ok but the plx looks a little easier to mount/set up but it has an internal logger so you can download it to your home computer.
There are others, FJO is nice but a little more pricey..
Iis a nice thing to have in the car, you dont have to guess what your a/f is..
Old May 4, 2004 | 08:41 AM
buschman's Avatar
Just out of curiousity, how does something like that install? Having no rear O2s anymore, would I have to remove the front O2 from one bank and install the wideband O2? If so, wouldn't that through the stock PCM for a loop causing it to mess up the AFR?
Mike
Old May 4, 2004 | 08:46 AM
kp's Avatar
kp
If you dont have cats just put it in the rear o2 bung if you have rear bungs - if not it only costs a few bucks to put a bung in. Some of them have a narrowband output and you can replace one of your front O2s with it and it will supply the pcm with a usable signal (need to wire it up yourself). I find it easiest to use it standalone since I put mine in other cars to tune them once in a while..
Old May 4, 2004 | 10:15 AM
scottywheels's Avatar
brad me to, we are both having the same problem, im sure nogo will be ale to fix it...
Old May 4, 2004 | 12:07 PM
Noyzee's Avatar
8 second mod
OK, so i dont need anything inorder to run the 300 one? i have no a-tap, efi,labtop, nothing. my tuner (aka NOGO) has it all, but hes about 2 hours from me so i need something fool proof. i never got labtop/a-tap do to the fact i couldnt figure it out, im no computer guy Thanks for the imput.
Scott, mine is BAD, yours is only a quick thing, mines forever.
im getting close tho
