Fuel pump setup dilemma! bahhhh
Ok, so im building my own twin in-tank fuel pump setup. I have a 99-02 style bucket setup. Well, i bought twin Walbro 450's, like the ones used on the squash performance setup. Come to find out, they will not fit in the stock bucket. Stupid me i guess. I spoke with andy over at squash, and he said that DW300's will fit in the bucket. So my question is, should i cut my bucket and run these, or just return them and use the DW300's. The DW300's are a 320lph pump, so 640lph total. shooting for 1000rwhp on 93/100% meth, twin turbo. The squash setup does not use a bucket, and he said they are coming up with their own bucket that will accommodate the twin 450's. But, it wont be out for at least 60 days.... Should i just wait? Id hate to drop another $4-500 to complete my fuel system..
I used this formula to figure my GPH i would need for my HP goal.. What do you guys think? (using a 25% drivetrain loss with a 4l80e/9")
Optimal GPH = (Max. HP x BSFC) / 6
so (1350fwhp x .75) / 6 = 168.75gph. 168.75gph = 638.7lph
So id be right at the end of the road...
Opinions.....Go.
Opinions.....Go.
Also, another option im considering is a nasty performance fabbed 14 gallon fuel cell with an internally mounted magnafuel 4303 pump. My tuner said he uses those pumps on the high HP cars. So if I go that route, ill return the alky control and go back to E85 as long as my injectors are up to the job. Ill call him on Monday and see what he thinks...
Heres the tank im looking at.
http://www.nastyperformance.com/shop...ing-fuel-tank/
I was prolly going to go ahead and get the extra external pump option as well. The 4303 is internally mounted so I shouldnt be able to hear it. My exhaust is pretty loud so it wont really bother me. I just dont want to have to worry about not having a fuel bucket.
To get back to your question about the stock bucket and to cut or not to cut, from all the research I did for my own swap, the reason not to cut is that fuel its returned into the bucket keeping the pumps supplied with fuel especially during turning, cornering etc. The bucket is essentially THE baffle in an un baffled tank. I've read many complaints from people about how they lose fuel around a turn with say 1/4 tank or so with a custom tank with an internal pump because of insufficient baffling.
If you don't give a rat's *** about any of that then by all means cut the bucket and use what you've got, if it concerns you think about using the physically smaller pumps. Lots of guys making it work either way. Just weigh the pros and cons for you.
That is the tank I have in my car with the MF 4303. I have a post on YB where I cut that mother f###er apart and added volume and helped the fuel sender that was a mile off, fixed the 2 leaks it had and quieted the loudest fuel pump noise I had ever heard. Here is the link http://www.yellowbullet.com/forum/sh...d.php?t=572083
I was just going by the intrawebzzzz... lol whats a good BSFC for a turbo app then ? .6? .65?
