those of you with the AES 390
Old Apr 17, 2015 | 11:01 AM
  #121
asubennett's Avatar
Originally Posted by rotary1307cc
Did u file the 1099 from them yet?
Silly internet haters.
Old Apr 17, 2015 | 11:39 AM
  #122
rotary1307cc's Avatar
Lol it was good don't lie
Old Apr 17, 2015 | 12:17 PM
  #123
asubennett's Avatar
It actually was. :-)
Old Apr 18, 2015 | 09:49 PM
  #124
kennyd351's Avatar
As i sit here and read this thread, wishing i had not delt with aes prior...I'll give a little history of my dealings with aes...fresh 324 cubic inch mod motor build, all 8 pistons clearanced themselves on the crank, the had failed to check for this...that was my first dealing...now as i sit in my garage just having taken apart a fresh less than 200 mile build, looking at a cracked crank,3 busted rods,a block with 2 holes in it...it looks like a spun rod bearing, after 200 miles, breaking in the motor properly, no passes, no dyno time,i had just taken the beak in oil out of it.and somehow i imagine they will blame the tune.
Old Apr 18, 2015 | 10:00 PM
  #125
Torqueshaft's Avatar
Bet on it...
That is ALWAYS the fall back.
Old Apr 18, 2015 | 10:36 PM
  #126
SM105K's Avatar
You didn't change the oil enough.
Old Apr 19, 2015 | 08:17 PM
  #127
BTS666.0's Avatar
i got an AES 390. apparently my tuner didnt tune in the proper clearances on a couple of pistons, and it caused said pistons to collapse skirts. or it was the bad fuel i use in australia. hard to be sure.
also looking at the state of all the bearings, in the motor, the engine builder i used to rebuild my engine, thats life could only be measured in hours, not kilometres or miles, says it was possibly assembled dirty.
pistons.
bores. some of the bores were .002 of an inch tight in the centre. not all of them. had to get them torque plate honed.
you can view other pics here.
http://s741.photobucket.com/user/bts...?sort=3&page=1
mike was great to deal with....right up until i handed over money. then he kinda backed off a bit. but still was ok to deal with when i could get him on the phone. shipping was a pain in the ****, but there was multiple reasons/excuses for this. not being there i will let shipping time slide, because some of the reasons are legit i am sure. and i am in australia. so extra paperwork etc....
the car was run in at the performance shop, and on the dyno. frequent oil changes. like they recommend and like i would do to a boosted car that is really only running on idle or wot. it did a few runs at the local strip, and started making a ticking noise. i thought it might be a stuffed lifter, but no, the sound was found to be the pistons rocking in the bores excessively due to the centre of the bore being tight. mike told me it was due to the tune. then bad fuel. for the record fresh fuel was put in before every meet.
when we pulled it all apart, and i sent mike pics of the bores etc, he said "race motor, no warranty". he did supply me new pistons at cost, so that was nice of him. after i had the machining done, and said to mike that machining cant be tuned in, and i appreciated having to spend about $3k rebuilding my new engine, he blocked me on facebook and messenger. no sense of humour.
i have called the shop twice and just get the run around. basically, i just gave up on them, and will never use them again. i learnt my lesson, and i will just pay more to have it locally built next time.
i wouldnt recommend them, purely on the service side of things. they may do great work, machining and all the rest, but my short block wasnt an example of it. very unhappy. anyways, best of luck to the guys who go them.
Last edited by BTS666.0; Apr 19, 2015 at 08:18 PM. Reason: bad spelling. grammar. still not good, but better :)
Old Apr 19, 2015 | 10:29 PM
  #128
dmaxvaz's Avatar
pistons.
Wow! I am amazed at how many people this has happened to.
Old Apr 20, 2015 | 04:44 AM
  #129
Mr Monaro's Avatar
Hi Guys l got 468 tall deck rhs engine built by Aes back in Fraser days took ages.I learnt my lesson deal local may seem more afordable but in long run cost lot more customs etc getting stuffed around .Im hoping engine was built with care still waiting for final tuning l always paid on time not good enough.
cheers
Old Apr 20, 2015 | 03:01 PM
  #130
Rare96LT1Formula's Avatar
I'm not sure about you guys, but I'm starting to notice a bit of a trend here.
But that's none of my business.
Rotary1307cc - POST IT UP! AES NEEDS TO BE HELD ACCOUNTABLE!
Old Apr 20, 2015 | 05:44 PM
  #131
asubennett's Avatar
pistons.
Sucks to hear - Thanks for the good luck. You know what's really interesting about AES. Guess how many sponsors are on this forum and other forums unrelated to the LS world that use AES for their machine work. It's funny because some of the complaints I have seen from AES moved their project to X shop and likely without knowing the new set up ended up being AES anyway. ha ha. At any rate - back up top.
Old Apr 25, 2015 | 02:50 PM
  #132
Any update OP?
Old Apr 26, 2015 | 02:38 AM
  #133
dmaxvaz's Avatar
Originally Posted by Rare96LT1Formula
Any update OP?
I had to buy another block, and I reused the pistons, rods, crank. The block had gouged cylinder walls. But my pistons had no scrapes, and were Sent to diamond to have them checked. So that tells me they used a junkyard block that they bored 30 over and still didn't clean up scraped up bores, and called it good Anyway. The motor/heads were redone locally, and I just dropped it in my tbss tonight.
Old Apr 26, 2015 | 09:12 AM
  #134
SSZ's Avatar
SSZ
Wish i was doing the same to my TBSS.
Sounds like they gave you a scarred block if the pistons are fine. Unreal.
Old Apr 26, 2015 | 09:42 AM
  #135
I can't yet. Don't worry when can I will
Old Apr 26, 2015 | 12:06 PM
  #136
mike06tork's Avatar
cheers
i have my RHS 461 getting build there im starting to loose my mind already my **** never got finish they gust keep giving me the run around. mike the supposedly engine builder that is never at the shop or always at the flow bench or at the dyno is hard to get a hold after you handle him your money. hopefully my **** get finish already and holds together because it has to make 2000hp.
Old Apr 26, 2015 | 12:56 PM
  #137
dmaxvaz's Avatar
I got the same runaround after I payed all the $$$ up front. they were at the dyno, flowbench, track, ect. You know what's funny? Is that Brian and Mike seem to be the same person. Btw, those RHS tall deck blocks seem to have a cracking problem. there are threads on yellowbullet about them
Old Apr 26, 2015 | 01:56 PM
  #138
asubennett's Avatar
For what it's worth, when I picked up my engine from them this past Monday, their were 3 RHS block motors being put together. 1 was bare but machined and 2 others were in final assembly phase if memory serves me correct.
Brian is older than Mike and is customer service oriented. Mike is younger and more technical but also customer facing. Their is about 15 other dudes in that shop that people never interact with.
I took some pictures of the shop (they encouraged me to do so). They had about 40 completed engines ready to ship out. About 40 in the waiting line. Probably 100 cranks tagged and ready for turning, polishing etc...
Like I said, their are some big speed shops in Chicago and near Chicago - not all LSX shops - that use AES that people about. Interesting.
Their were a few LSX block builds. A few 4 bolt headed LS motor builds like mine. Some dart block builds. BBC builds. SBC builds. Ford builds. Mopar builds. 4G63 builds and on and on and on.
I'll report back about how my motor performs both on the dyno and the track. The guys at AES actually let me watch final assembly of my motor as well as entertained my 7 year old boy with lot's of stickers and giving him a sneak peak at their KOTS car etc...
I can't defend anything that has been reported in this thread. Only offer an alternative view point. That is all. Hope everyone else finds resolution to their issues.
Old May 1, 2015 | 03:36 PM
  #139
2JZFC's Avatar
I usually avoid these vendor-bashing and mud-slinging discussions. Was hoping there could be some resolution to my dispute with them, but now I just have to chime in.
Even though I am really pissed, I am not going to get into a long drawn out public discussion of my issues with them. I am retired and just trying to enjoy the tail-end of my life and decided to cut my losses and take it up the butt-cheeks from them. Won't go so far as to call them crooks, but they are unethical with bad business practices and a total disregard for the customer, with the end result the same.
Based on what I am reading, there seems to be 2 sides to AES, the one that caters to the racers and $$$ customers and those they deal with mail-order. I may be just another irate guy spewing words behind his keyboard, but based on my experience dealing with them, I would strongly advise anyone out there considering a build to look somewhere else.
That is all.
Old May 1, 2015 | 05:15 PM
  #140
That is all.
Contact the Illinois Attorney General.
Sad to see the sheer volume of wronged customers. It isn't right, nor should it be tolerated. Looks like Thunder Racing Part II in my eyes.
When they're out of business, they'll have quite a bit of free time on their hands to contemplate all of their negligence. Brian wants to cry wolf for people "talking **** on the internet", but doesn't want to take care of the people who keep him in business, not to mention that Chevy of his sponsored..
