FIC2000 and E85 issues.
Old Oct 14, 2013 | 07:24 AM
  #41
skinnies's Avatar
Originally Posted by allout06
If I have issues with these, ill switch to a low z Moran 235 lb/hr billet atomizer injector with an AEM driver box.
Might call and talk to them about running their injectors and e85, they wanted me to purge them out with pump gas every 3 days or you will have issues.
Old Oct 14, 2013 | 07:38 AM
  #42
allout06's Avatar
On the moran injectors? Are there any E85 compatible injectors out there??
Old Oct 14, 2013 | 07:50 AM
  #43
skinnies's Avatar
I'm running the siemen 220's, they are made for e100 from the factory, they are NOT A MODIFIED injector. So far no issues with mine.
Old Oct 14, 2013 | 08:08 AM
  #44
hellbents10's Avatar
LS1Tech Sponsor
I don't know about Ethanol but on M1 we have to purge the Morans with gas after every race weekend or they go south quick.
Old Oct 14, 2013 | 08:25 AM
  #45
rotary1307cc's Avatar
You don't want the Morans for street duty. They even say so
Old Oct 14, 2013 | 09:32 AM
  #46
allout06's Avatar
Ok. Well **** me. Im assuming the siemen 220s are low impedance as well? I wanna see how far the FIC 2000'S get me before I switch. Maybe I'll be one of the people who have good luck with them..
link to those siemens?
Old Oct 14, 2013 | 10:28 AM
  #47
Camper's Avatar
has this car sat for periods of time?
Old Oct 14, 2013 | 10:33 PM
  #48
I8UR4RD's Avatar
I have whatever lines lonnie sends with his e85 kit. The filter he sent and recommends is a fiberglass element 6 micron from fuel lab. It's all yet to be tested but a better element may help.
 Michael S. Palmer
Old Oct 15, 2013 | 02:55 PM
  #49
Joe6pt0's Avatar
Originally Posted by 1INSANEGTO
Hmmmmm interesting I just bought FIC2100's and running e85. What are the signs of issues?
Missing and seeing lean readings on one bank (first set I had were on each bank). I have dual widebands so makes it easier to diagnose when this starts to happen, but the first time it was tough since one failed on each bank. Usually several fail at the same time. Some seem to spray ok at low RPM so I don't notice until i start to really drive the car. Others fail completely to the point where no fuel at all comes out. It's easy to see the lean condition on the wideband and feel the miss when one isn't firing at all. Also gets worse with temperature so often cold start will be fine but after a minute or so of driving they stop spraying. Jon saw the same thing on his tester when I shipped them back.
See my post on top of 2nd page. Car usually sits for no longer than a week or so. Exception was over this past winter, it was down for 5 months. But I had pulled the injectors off the rails when I took the car apart so they say for 5 months with no fuel. They were fine when I took the car apart.
When Jon sends me the new set back I'm going to sell them on here. Since others have had good luck, it must be something unique to my setup. I assume its the extra heat mine sees vs someone who doesn't drive the car out of town for 4-6hrs in summer heat.
Old Oct 15, 2013 | 02:57 PM
  #50
Joe6pt0's Avatar
I forgot to add that this last time I noticed when driving it felt down on power. I stopped at the parts store for something and after starting it, it seemed fine. I ripped on it pretty good and hit the rev limiter. Immediately noticed a bad miss and it never went away even when cold starting. So whatever happens, happened that very moment of higher duty cycle (I only see 60% DC max).
Old Oct 16, 2013 | 07:15 AM
  #51
Sarg's Avatar
Dang, making me think I need to pull my 160s as they are exhibiting very similar symptoms. Guess I will just be out the cash I spent on them. Maybe I will throw in some cheap 80s for now. What injectors are good in the 100 lb/hr range on e85 that are hi-z?
Old Oct 16, 2013 | 07:37 AM
  #52
allout06's Avatar
The bosch 127s will work with E85
Old Oct 16, 2013 | 08:24 AM
  #53
Sarg's Avatar
Yeah was really hoping not to throw another $900 after these $1100 injectors turn out to be junk.
Old Oct 16, 2013 | 08:34 AM
  #54
95bowtie's Avatar
Got a feeling the same thing has happened with my FIC 72's. They are siemen dekas more than likely 60's opened up a little.
I called and asked if my 72's could be opened up to 80 and he says that's not a problem. I'm going to have them inspect them first to see if some were clogged.
I have been chasing issues with my tune....or so I thought.
I raised my base fp from 40 to 60 and was in the process of retuning it my self but couldn't get my VE right and my STFT's were all over the place always.
I noticed one bank would read +40 while the other would hover around +30.
I pulled the plugs and all 4 on the driver bank were light grey/tan color and weren't black or wet or anything out of the norm.
Pass. side had one black plug and two that were very very light tan color with no change over line at all on the strap. Which from what I've read the line where the color on the strap goes from grey to a tan color and where it changes at just dictates whether you have the right heat range or not. Either way it wasn't on three plugs out of 4 on that side so something isn't right.
For whatever reason while all this is going on the car won't idle or cruise at any AFR other than 13.80 or so. Stoich is setup for alcohol and is at 9.89 I do believe. Speed inc. tuned the car on e85 and 40psi base pressure and it would idle around 14.5-14.8 AFR when picked up. Now my fuel trims at idle will be +/- 5 and wideband was showing 13.80ish as always. Very strange to say the least.
Old Oct 16, 2013 | 03:18 PM
  #55
Sarg's Avatar
Justin, what has your experience been with the low-z injectors? Easy to tune? Perform as well as hi-z injectors? Anyone know if the bosch 160 low-z injectors have issues?
Old Oct 16, 2013 | 06:07 PM
  #56
Joe6pt0's Avatar
From the first or second page, it was said the 160 and 200 (1600 and 2000) have the same core and are both CNG. This is what Jon@FIC told me as well, which is why I am ditching the CNG injectors all together and going with the Bosch 127s. Jon even recommended that.
Old Oct 16, 2013 | 06:51 PM
  #57
I8UR4RD's Avatar
are 127's going to support your fuel needs at 900+ rwhp on e85?
Old Oct 16, 2013 | 07:02 PM
  #58
allout06's Avatar
High 900s will be pushing the injectors to the 90%+ duty cycle
Old Oct 16, 2013 | 07:28 PM
  #59
stock48's Avatar
9 Second Truck Club
Do you run any additive in the E85?
Old Oct 16, 2013 | 08:57 PM
  #60
Sarg's Avatar
Ah, so is that the Low impedance as well as the high impedance injectors that are all CNG injectors?
