Looking at going turbo.
Old Nov 3, 2013 | 11:44 AM
totalchaos's Avatar
Default Looking at going turbo.
So I was just going to do a h/c/I with a shot nitrous. But lately I have been spending lots of time in this section looking at different set-ups and trying to learn about it. Really like the idea of power on demand without having to fill the bottle and different tunes when I want to spray. Car is 99% street car. Narrowed it down to 2 kits , Huron Speed or the On3 Performance a/c kits. I know both need a turbo k-member. Could I run either one with the a/c removed until I could get the k-member?
Old Nov 3, 2013 | 12:34 PM
Blackpanther99's Avatar
Sure why not.
Old Nov 3, 2013 | 12:54 PM
ss performance's Avatar
If you can afford it turbo is the way to go.
Old Nov 3, 2013 | 02:42 PM
willizm's Avatar
Reach out to TurboJoe@straightline. He can fab you a kit to keep the stock kmember and AC. His turbo headers are some of the best on the market.
Old Nov 3, 2013 | 04:17 PM
DEFYANT's Avatar
The K-Member is needed for header clearance, so no.
Old Nov 3, 2013 | 04:52 PM
totalchaos's Avatar
The motor build looks like this:
block : ls1
crank : stock
rods : Eagle or Scat 6.125
pistons : ?
oil pump : ported ls6
heads : 799's with a valve job (already have)
cam : comp cams - 223/231 - .610" / .617" - 115+4 (already have)
springs : BTR-S 002 max pressure .650" duals (already have)
lifters : ls7 or btr with new trays
timing chain : ls2
rockers : stock with comp or btr upgrade
intake :Fast 92 (already have)
tb : Fast 92 (already have)
head gaskets : ls9
head bolts : arp
How does that look so far?
Old Nov 3, 2013 | 05:42 PM
T76s10's Avatar
I would sell your fast intake and tb because you won't need it and the money could be better spent. The stock crank has made over 1k so I would use that.
Old Nov 3, 2013 | 08:21 PM
totalchaos's Avatar
For now the fast set-up will be staying. If I do get a different intake I think it will be an ls2. What would a good stall be for a turbo combo. I was going to get a 3600 before. Do you need anti-ballooning option?
Old Nov 4, 2013 | 07:07 AM
T76s10's Avatar
i just called ptc and have them make me one off of my specs for my combo.
Old Nov 4, 2013 | 08:53 AM
Superman09's Avatar
LS1Tech Sponsor
Let me know if you have any questions and I would be more than happy to help you out! We can build you a set-up with as nice of components as you like and also get you set-up with components that will meet your current and future goals so you do not need to change or upgrade later on! We have a terrific special going on right now you should check out which includes a nice Precision charger with the 75mm turbine wheel, which really works well on the LS1 sized engines and will not choke you out when you start spinning it higher and making more power!
https://ls1tech.com/forums/forced-in...e-package.html
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Nov 4, 2013 | 09:59 PM
totalchaos's Avatar
I would love to pick up that kit , just not in the budget . Car is parked for the winter and no place to work on it. My plan was to buy pieces through out the winter. sent you a pm this morning.
Old Nov 7, 2013 | 08:16 AM
totalchaos's Avatar
So I think I found my hot side. It's modular turbo set-up. Decided to lose the a/c completely. Any reviews on it? Yes I searched but not reviews on it.
Old Nov 7, 2013 | 08:23 AM
Camaro9969's Avatar
You narrowed it down to those two? Make sure you get the right kit for what you want. The right kit goes a long way with these builds
Old Nov 9, 2013 | 09:44 AM
totalchaos's Avatar
Read your build thread the other day. Awesome work there and great numbers at the track.
Old Nov 10, 2013 | 08:58 AM
totalchaos's Avatar
Should I sell or trade my 799 heads for a set of 317 heads.
Old Nov 10, 2013 | 07:15 PM
HexenLord's Avatar
Depends on why you want to switch. Just looking to lower the compression?
Old Nov 10, 2013 | 08:07 PM
totalchaos's Avatar
that's what I was thinking. guess I could get some dished pistons.
Old Nov 11, 2013 | 04:57 PM
totalchaos's Avatar
Ordered my hotside from Huron Speed today.
Old Nov 11, 2013 | 04:58 PM
Superman09's Avatar
LS1Tech Sponsor
Glad to be of help and get you set-up. Be sure to let us know if you need anything else!
Jon
__________________
Old Nov 11, 2013 | 09:36 PM
totalchaos's Avatar
Jon
Oh for sure.
