TT manifolds?
Old Nov 10, 2013 | 06:58 PM
6togo's Avatar
Default TT manifolds?
Thinking about using either truck or Ls3 camaro manifolds for my twin 427 build probably be making around 1k HP will they handle that kinda of power and by using mani's VS tube headers will i be giving up allot of power?
Old Nov 10, 2013 | 07:02 PM
HexenLord's Avatar
Lots of guys making power way up there with truck manifolds. its honestly not worth changing to tube style manifolds until you either plan to fan them for custom figment or you're cresting well over 1000whp.
Old Nov 10, 2013 | 07:06 PM
Boo"SS"t's Avatar
Either one of the cast factory exhaust manifolds will easily make well over 1k rwhp. Unless you're going all out and trying to break a record, then you'll need a set of custom build turbo headers.
Old Nov 10, 2013 | 09:09 PM
6togo's Avatar
I plan to make around 1000rwhp and the mani's tuck up nice and tight which i like and i dont like the price tag of custom headers though they do look pretty!
Old Nov 11, 2013 | 05:34 PM
6togo's Avatar
Bump any other input on Mani's? Anyone take some time an clean them up so they look better?
Old Nov 11, 2013 | 10:28 PM
97WS6SCharged's Avatar
If you mean the ports you could have theme extrude honed. If you mean just making them look pretty a ceramic coat would do that and help with heat retention.
Old Nov 11, 2013 | 10:43 PM
6togo's Avatar
I was was just curious if anyone grinded the towers off and maybe smoothed them some.
Old Nov 12, 2013 | 09:23 PM
96lsximpalass's Avatar
I just picked up a set of pace setter truck shorty headers for real cheap. there direct replacement for the manifolds. they look a lot cleaner!
Old Nov 13, 2013 | 07:08 AM
6togo's Avatar
Too bad they dont have a SS version they might have worked with a flange swap!
Old Nov 13, 2013 | 06:42 PM
6togo's Avatar
Anyone use those Holley cast manifold for boost yet?
Old Nov 13, 2013 | 07:19 PM
Forcefed86's Avatar
Truck manifolds have made over 1500whp on a single setup. They work great and weld great. Unless you want weight savings, no real reason to use anything else. Wrap them if you don't like how they look.
Old Nov 13, 2013 | 07:29 PM
transam69230's Avatar
Some good info in here on how smoothed out manifolds look like with coating.
https://ls1tech.com/forums/forced-in...lock-here.html
Old Nov 13, 2013 | 09:25 PM
6togo's Avatar
Might just have to try a set and see how they fit what years have the least amount of junk on them and are truck manifold's symmetrical?
