5.3 lm7 opinions needed!!
Wanting forged internals.
Ls9 head gasket.
Decent cam.
ARP hardware.
New crank?
Oil pan.
New springs.
Fuel rails.
Fuel injectors.
That's a broad list of the upgrades I want to make. Anyone have good recommendations for which parts are best as far as brand, part #'s, etc.?
Thanks!!
https://ls1tech.com/forums/forced-in...impala-ss.html
Would 80lbs injectors start running out around 700whp? Do I need to do anything as far as fuel rails?
This is my first time doing a build, and I'm jumping in head first. It'll be a long process, but I wanna make sure I get everything right. Thanks!
E85 is super rare both where I'm stationed at now and back home, so pump gas and meth is what I'm gonna do.
Like I said, this is my first major build. I'm just confused/ not 100% sure on how to choose upgrades because of sizes and whatnot.
I'll be taking the short block to a shop to have it hot tanked, true all the surfaces, and if need be, get it bored. Then I'm gonna go from there. But I wasn't sure on which companoes male good forged internals for these motors.
Dude if it helps any, Im doing a 800-900 whp turbo build and im using a lm7.
So far all i have done is sent the block out to get cleaned, new cam bearings, and a light scuff on the cyl walls to seat the new rings.
Im using all of my factory internals. I just put new bearings and rings in it. I bought a new oil pump and a billet single timing chain.
As far as ive seen this stock stuff will take abuse.
I'd like to get this build done fairly cheap, but I also don't mind a little extra insurance as far as longevity since it'll be a street car/ daily. Haha
Oh i did use arp rod bolts.
I found a shop here that'll hot tank and clean everything for about $150. Should I get heads and all that stuff cleaned while I'm at it, or would it be fine to jist throw them on there as is?
60 lbs injectors have been known to make 700 rwhp so in that sense, 80's will be plenty. With meth though, it takes some stress off your injectors and pump so you could get away with 60's if you went that route. The 76mm is a good size for a stick car. I love mine. Spools quick between gears and it's a blast on the street!
Never heard of using LS1/6 head gaskets...I used the stock 6.0 MLS gaskets on mine and they are awesome. They fit a 5.3 without issue since the bore size is so close anyways. My bottom end is all stock but I have ARP head studs. Very solid combo.
And ya, I've read several threads where people opt for the ls1/6 gasket since it's cheaper and apparently works just as well...
I'd like to do it fairly cheap, but I'm also trying to get "fast, reliable, and somewhat cheap" haha
