Camaro ls2 with borg Warner s475
Old Nov 25, 2013 | 12:47 AM
sahwan's Avatar
Default Camaro ls2 with borg Warner s475
I have Camaro ls2 turbo I tune it yesterday at 9 psi it made +600whp ,+600wtq with pump had ,is it safe for the engine ??
My setup
317 polish head with valve spring
ls9 gaskets
Ls9 cam
All ARP bolts
This is the dyno video
http://youtu.be/td-HSKBkwtw
Old Nov 25, 2013 | 06:55 AM
Camaro9969's Avatar
That's good power for 9psi as for the word "safe" that can't be answered without knowing your tune or many other things. How much timing? Stock bottom end? What fuel? Id say 9psi is safe and isn't going to hurt anything. A s475 hasn't even woken up with that low of boost.
Old Nov 25, 2013 | 11:13 AM
sahwan's Avatar
It's stock bottom with all arp bolts in the engine , the fuel is 91 pump gas , the timing is 16 degree and the afr is arond 11.4 to 12.1 , the turbo is good in that boost
Old Nov 25, 2013 | 11:18 AM
sbcgenII's Avatar
http://www.youtube.com/watch?v=td-HS...ature=youtu.be
Old Nov 25, 2013 | 12:35 PM
sahwan's Avatar
Thanks
Old Nov 25, 2013 | 12:41 PM
Camaro9969's Avatar
91 octane 16* if you want to be "safe" with that gas take out a little timing and instead of that big range of afr in boost knock it down to 14* and 10.8-11.1 max
to me that would really be safe.
Old Nov 25, 2013 | 12:46 PM
Rise of the Phoenix's Avatar
What does your fuel setup consist of?
Old Nov 25, 2013 | 01:36 PM
sahwan's Avatar
I will use 95 octane soon
Old Nov 25, 2013 | 01:42 PM
sahwan's Avatar
aeromotive 340lph single fuel pump with hot wire in stock fuel line with siemens 60lps injector
Old Nov 25, 2013 | 06:19 PM
Blackpanther99's Avatar
Stout numbers for the amount off boost
Old Nov 26, 2013 | 03:36 PM
sahwan's Avatar
Thanks
Old Nov 26, 2013 | 06:58 PM
89ROC-Z's Avatar
Nice! What size turbine on the turbo?
Old Nov 26, 2013 | 11:58 PM
sahwan's Avatar
Borg Warner s475 with 1.32 a/r T6
Old Nov 27, 2013 | 12:11 AM
need2speed94's Avatar
I agree with this ^^^ I've noticed there's a few things in common between the guys that are keeping their stock shortblocks alive under boost... Timing is conservative @ 15* or less like stated and AFR is kept rich. Besides common sense, I think those two things are vital to keeping the stock bottom together.
Old Nov 27, 2013 | 02:53 AM
sahwan's Avatar
Yes I agree with you
Old Nov 27, 2013 | 09:09 AM
89ROC-Z's Avatar
How is spool up with the turbo? Do you think a later spool also helps these stock short blocks live by not running 15psi at 4k rpm?
