THE LIST-Top 10 STOCK BOTTOM END LSx(s)
#201
I would just toss a **using 245 dragster** and mention the weight, but the fastest imports for all motors are in 3/4 or dragsters as well.
#202
Restricted User
I think someone would know somethings up with the 1550 lb weight lol.
I've been considering it... I know based on some of the times these guys have ran, a stock Gen 4 4.8 could probably hit mid 7s without much effort only pushing 1500 lbs. The question is, will it do 6s?
#203
2) We still need someone in the 7's. Thats the next frontier. Make it happen!
#204
#205
If thats true, I think that officially boots him from this list. Even int he rods/pistons are stock half-filling significantly increases the rigidity of the block-and is not a far comparison to a true JY motor, IMO of course.
What do people think about that?
#209
Impressive-whats is the guy's user name on here? Any more info?
O-ringed and filled but still extremely impressive. Still fits the bill has a stock SBE to me if it has stock Pistons and rods..
#212
Restricted User
Shawn is a member on this forum.
Has ARP rods bolts for the 7800 or so RPM he runs and a half filled aluminum block. Stock crank, pistons, rods, and runs 799 heads.
Id say the half filled aluminum block would put it on par strength wise with a 5.3 iron block, so I wouldn't rule him out for the block alone.
#213
Made 730 today on a sbe 5.3 at 18psi and only 14* degrees of timing on e85
Unlocked converter
Was hoping to run it up higher but couldn't get the dyno to load the turbos that well
Unlocked converter
#214
Many people say ARP lower end hard ware should not count for SBE. I'm 50/50 on that.
This thing is fully ARP...O-Ringed...AND Filled block?
Common....I'd love to hear what others think but I don't think that would count.
Nice! Have a build thread?
#217
8.23 @ 159 mph, 1.16 60ft. Stock LS6 bottom end, ported 243's, cam, and TVS2300 @ 10 psi. Just making some shakedown passes on a new build. 207" rear engine dragster. Estimated weight is 1500 lbs (still need to scale it). Working on getting the videos edited, will post soon.
