THE LIST-Top 10 STOCK BOTTOM END LSx(s)
#244
Restricted User
#245
#247
1) We have not been keeping track
2) so much of a good 1/8th car is set up/gearing that does not directly transalate to the 1/4. But the same could be said of the dyno.
#249
The blue foxbody in that video outrunning the green "dragonfly" is the one i was talking about.
It has a stock l33, stock heads, stock intake, ljms camshaft, and an s484 on quite a bit of boost. Pump gas and meth.
#253
Restricted User
I don't have Facebook but is this the car you are talking about?
REAL STREET GETS REAL INTENSE! - YouTube
#255
Are either of them on the forums?
#257
Green car is duane biddle, car is called the dragonfly
The blue fox is bambam owned by derrick kelly.
My sbe 5.3 has been 9.0 at 151 on fairly low boost
Should go quite a bit faster this year
#260
I've been 9.54 @ 147 with an 03 LQ4 (weak rod), cast S480 92mm 1.10, SRD cam and a 4L80E leaving off the footbrake and running 15-16 lbs. down the track. New turbo and MS3 pro going on the car and should be ready in the next few weeks. Going to see if the old LQ4 has a 4th year of abuse in it.
