THE LIST-Top 10 STOCK BOTTOM END LSx(s)
Old 09-05-2014, 11:37 PM
  #121
Forcefed86's Avatar
Went 9.55 @144 tonight with the 2006 4.8.
18lbs of boost. S476 turbo 15* of timing
Isky Tripple 12 cam
unported 4.8 706 heads
Ls1 intake/TB
Glide 3.25 gear
2880 lbs.
60 shot on the t-brake.
Pretty good for low boost I thought. I've got a new IC and LS6 intake ready to bolt on. Should be in the 8's with 25lbs or so I'd bet.
Old 09-05-2014, 11:41 PM
  #122
3pedals's Avatar
I'd say thats definitely a thumbs up on a 4.8!
Old 09-06-2014, 09:58 AM
  #123
kjm
kjm's Avatar
Nice work forcefed. That thing is moving. Can't wait to se it on kill. We might have a new 4.8 record soon ��������
Old 09-06-2014, 12:03 PM
  #124
Forcefed86's Avatar
I'll give it a shot! I'll have the MPH... but Lavory's 8.85 time will be hard to beat. His 60' and 1/8 times were miles ahead of anything I've ever pulled off in this car.
Old 09-06-2014, 12:39 PM
  #125
chikn305's Avatar
Hoping to get on the list soon. I'm building a lq4 bottom end with dart as cast heads s480 btr cam. It'll be in my 87 formula
Old 09-06-2014, 08:37 PM
  #126
nofxgivn's Avatar
3pedels how is your car doing?have you had any new bests yet?
Old 09-06-2014, 10:05 PM
  #127
3pedals's Avatar
Only had car out 3 times. Small issues plagued each of my 3 test days - poor wiring, bent throttle rod twice
Car is done for season and I am going to re wire my car and try out holley efi.
Old 09-07-2014, 01:17 PM
  #128
coltboostin's Avatar
When you say "building" you mean leaving it stock right?
Isky Tripple 12 cam
Ls1 intake/TB
Glide 3.25 gear
2880 lbs.
Nice! Still in the FB? Why the motor change? How doe sit "feel" off boost compared to the old mill? Is the No2 off the line making up the difference?
Old 09-07-2014, 04:49 PM
  #129
Forcefed86's Avatar
6.0 will def. be a stocker. Bought a set of gen4 pistons and rods for $100. Got a few cranks laying around. Been looking for a deal on a 6.0 block.
Yup still the FB. Blew the headgasket on the 5.3 and it scorched the deck and head pretty good. When I pulled the 5.3 I sent the converter out to get restalled tighter in anticipation of the 6.0 install planned this winter. I believe the old converter would have been a great match for a 4.8. Using the nitrous to squeak by with this converter for the rest of the year. 4.8 feels like a dog compared to the 5.3. But who knows what the 5.3 would have felt like with this new converter.
Nitrous helps a ton. I plan on upping the shot from a 60is to a 80ish. N20 is on for roughly 1000 rpm and builds 6lbs by 4100 and shuts off, after that motor/boost takes over and hits about 13lbs by 4800rpm where I launched.
Old 09-07-2014, 05:35 PM
  #130
ls1curt's Avatar
My buddies truck just went 8.68@156. Stock bottom end 03' 5.3 with s480 at ~3150lb
Old 09-08-2014, 10:49 AM
  #131
Thats s10? What is his handle on here?
Old 09-08-2014, 12:13 PM
  #132
ls1curt's Avatar
Yeah. I don't think he's on tech
Old 09-08-2014, 03:15 PM
  #133
I thought he was?
Either way, he would have to be on tech and post proof (dyno/slip/video) to be on the list. Get him on here!
Old 09-09-2014, 10:16 PM
  #134
MR2liter's Avatar
I've got a few to add to the hp list.
828whp.
02 SS
stock longblock ls1
234/244 115+3
D1sc 16psi
e85 + meth
procharger fmic
6 speed
https://ls1tech.com/forums/forced-in...es-808whp.html
704whp
02 SS
stock longblock ls1
234/244 115+3
F1r 14psi
e85
Twin intercoolers
6 speed
https://ls1tech.com/forums/forced-in...1r-700whp.html
715whp
99 c5
stock shortblock
tfs 215
224/234 114
p1sc 11psi
e85
twin intercoolers
4l60e 3400 stall
https://ls1tech.com/forums/forced-in...si-700whp.html
Old 09-10-2014, 12:22 PM
  #135
828whp.
02 SS
stock longblock ls1
234/244 115+3
D1sc 16psi
e85 + meth
procharger fmic
6 speed
704whp
02 SS
stock longblock ls1
234/244 115+3
F1r 14psi
e85
Twin intercoolers
6 speed
715whp
99 c5
stock shortblock
tfs 215
224/234 114
p1sc 11psi
e85
twin intercoolers
4l60e 3400 stall
These all your cars? Also, I thought the F1r is larger than the D1sc?
Old 09-10-2014, 01:05 PM
  #136
MR2liter's Avatar
mine is the white 02 with the f1r. The two others are customers.. yes the f1r is larger then the d1 but the d1 has better supporting mods.. 2" headers vs my 1 7/8. Larger piping and fmic vs my twin ic. D1 car also has meth allowing more timing in the tune.
Old 09-10-2014, 03:15 PM
  #137
I dont know how headers and piping account for 130whp-that sounds aufly fishy-especially considering it is a smaller blower. I will add tyou car, but people have to have a Tech USN and be at least a semi-active poster to maker the list. If we let everyone post for their dad/son/uncle/brother....ect it may get out of hand. Have to draw the line some where!
On another note-Did you guys build a Corvette for Jamie Cater? Your shop looks familiar.
Old 09-28-2014, 12:31 PM
  #138
Forcefed86's Avatar
Fought gremlins all night with the 4.8. Couldn't make over over 18lbs of boost. It was either 18lbs or spike to 30+! Think I need a new WG.
Looks like it picked up 4+mph with an intake and intercooler swap at the same boost levels and 2* less timing. (went from 17* to 15*) Pretty happy about that.
This was pedaling the car heavily all through most of 1st gear and short shifting at 6500. 16lbs in low gear, 18lbs in high. Easy low 9 sec pass with good 60'.
Old 09-28-2014, 05:37 PM
  #139
Sbryson02's Avatar
Not sure if you allow cars with rod bolts on the list. Some guys complain some don't. If you don't that's cool. Stock rods with ARP bolts, stock pistons, stock crank, grouted stock block, ported stock heads, eBay chinese head studs. On methanol with a GT5588. 2965lbs race weight. Best ET 4.83 best MPH 151.3
Old 09-28-2014, 08:18 PM
  #140
Thats up to the group-I'm not sure. I'd be fine with it on the list-I dont think its that much of an edge. Bigger question, ever run it in the 1/4? Its hard to gauge an 1/8th mile car to 1/4 mile times if the car is set up to run out the 1/8th. Either way that is COOKING. Is that straight meth, or meth injection on top of regular fueling?
Updated. Great work!
What IC did you go to/from?
Quick Reply: THE LIST-Top 10 STOCK BOTTOM END LSx(s)
