Time for some upgrades to the Turbo Firehawk
Old Jan 28, 2014 | 06:16 AM
RacerXLs1's Avatar
This car had came a long way, can't wait to see your new results.
Old Jan 28, 2014 | 07:00 AM
TNTramair's Avatar
nice work Dan. cant wait to see the outcome.
Old Jan 28, 2014 | 08:14 AM
dschmittie1's Avatar
thanks guys yes it has come along way in the almost 9 years that I have owned it
Old Jan 28, 2014 | 09:42 AM
Heavy H.P.'s Avatar
Originally Posted by dschmittie1
Well as of right now I have someone that said they will take it.
Booooooooo!!!
Well if the deal doesn't go through shoot me a pm.
Old Jan 28, 2014 | 08:39 PM
I made the rad mount tonight and got all my brackets made for the intercooler. I will be taking the intercooler over to 1fastbird's house tomorrow night to get the mounts tigged on. I should have all my flanges, pipes, and wastegates by the end of the week so I can really get the ball rolling on the new hot side.
It is crazy how much room there is up front with the rad pushed up into the nose
Old Jan 29, 2014 | 12:11 AM
conan's Avatar
Looking good, in for results.
Old Jan 29, 2014 | 02:39 AM
Blackbob's Avatar
Sub'd
Old Jan 29, 2014 | 03:14 AM
venom ws7's Avatar
Looking great best of luck
low 8s with street car will be awesome that support sure does give a lot of room.
Old Jan 29, 2014 | 07:14 AM
98Camarod's Avatar
I'm liking the progress Dan. I'll most likely be doing this next winter as well.
Are you not going to use fans on the radiator?
Do you already have your trans cooler with fans in the back?
What pump are you going to use for the intercooler?
Where are you putting the water tank?
Old Jan 29, 2014 | 11:50 AM
Thanks guys.
I sold my pusher fans and I will be ordering a set of puller fans and making a shroud for them. I am planning to buy a 5 gallon tank with the rule pump mounted inside of tr tank like the one chiseled makes.
My trans cooler has been mounted under the car with a fan for 3 years now. Although I will have to move it now due to changing my sow pipe routing. Not sure where I will place it now
Old Jan 31, 2014 | 04:33 PM
I got a good bit done last night. Intercooler has brackets on it and is mounted. I modified my new truck manifolds and added V bands to them.
My new T6 flange showed up today along with my new wastegates. I should be able to get the Majority of the hot side fabbed up Saturday. and be ordering cold side pipes early next week. This are coming together quickly
Old Feb 2, 2014 | 09:42 PM
  #32
I got a lot done Saturday. I got the turbo mounted and the hot side all tacked in place. I will finish welding that this week and order what I need to do the Cold side and plumb the wastegates. And I will pick up a few 4" bends to piece the downpipe together
Old Feb 5, 2014 | 02:27 PM
  #33
DEFYANT's Avatar
Looks good Dan! I like the forward facing turbo!!
Old Feb 5, 2014 | 03:02 PM
  #34
Thanks I am really happy with how things are turning out. I have cold side pipes and v bands on the way.
unfortunately my washing machine died at the house this past weekend so that is going to slow up some of my progress on the car
Old Feb 5, 2014 | 06:33 PM
  #35
98Camarod's Avatar
How many clothes does the car use?
Old Feb 6, 2014 | 09:24 PM
  #36
giiventofly's Avatar
Looking really good Dan! Can I get a ride in that thing this year pleaaaaaaseeeee?
Old Feb 7, 2014 | 07:47 AM
  #37
It uses all the clothes I get dirty working on it
Sure thing
Old Feb 7, 2014 | 08:00 AM
  #38
Well I got the wastegates plumbed last night. Hot side just needs some welds ground/cleaned up inside the flange and then it is ready to be coated and wrapped. All of my parts to do the cold side piping should be here by Tuesday.
I also need to get to my local truck parts warehouse and pick up some 4" bends to work on my downpipe.
Here are a few updated pics
Old Feb 17, 2014 | 09:07 AM
  #39
Well I got some done in the last couple days. I got the hot side all painted and wrapped including the manifolds. I did shave all the mounting bosses of the truck manifolds to make them look cleaner. I also started mocking up the downpipe. V-bands got welded to the intercooler and I will be able to mock up the cold side this week as well.
I still need to order a set of injectors and the ice tank soon.
Old Feb 17, 2014 | 02:11 PM
  #40
93camaro_zzz's Avatar
Looking great Dan! What did you use to paint everything with? A high temp black of some sorts? I'll be finishing up my 4" downpipe as well on my car, just wish I knew a local place that sold 4" mandrel bent like you. lol
