Time for some upgrades to the Turbo Firehawk
I am having an issue with my wideband though. I can't get it to read anything leaner than 10.0 at idle and cruising. I have leaned it out to the point stalling at idle. So it is either my wideband that died or my OS sensor placement is bad. I am swinging by a friends tomorrow to try his stand alone Wideband and see how his reads.
Here are some pics before I took it apart and also current O2 sensor location.
However I turned the boost controller on and didn't think to change some of the settings on it. Needless to say I made a pull and saw 30 psi of boost(felt crazy fast). AFR's were safe but #6 cylinder liner had other plans
Looks like I will likely be down for the rest of the season.
30psi though! That had to be a ride yeah?
Bummer to see the block broke on ya. Thats alot of juice pouring that hole for sure.
Nothing else was hurt right? I'll keep my eyes peeled for a block for you.
What heads are those?
Motor has 205 AFR heads on it. They took some damage but they are easily fixable. I will post more pictures once everything is out and torn down
All the car needs to be complete is Pistons, cam, lifters, push rods, valve springs, gaskets and machine work. Everything else is there for a proven chassis and turbo kit that is 8.50 legal.
Looking for $20k OBO. This includes a ton of stuff for the car and some extras.
Will even considering welling with my enclosed 24' haulmark trailer. for $23K
I should have a thread with details in the next day or 2. I need to sit down and look at everything I have to finish my list of what goes with the car.
