~NEW Huron Speed V2 Single T4 Turbo Kit *GROUP PURCHASE*
Old 02-27-2014, 10:26 PM
  #101
blackbird0230's Avatar
What Bov and Wastegate do you recommend for a stock LS1 with boost cam looking to hit 6 lbs at first. Then crank it up if the tune holds. And are the mounts for them still a 2 bolt set up?
blackbird0230 is offline
Old 02-27-2014, 10:29 PM
  #102
LS1Tech Sponsor
Superman09's Avatar
I would run the XS-Power 50mm BOV. It looks and sounds great and we've never had a single issue with them. Can't beat them for the price! For the waste gate I'd really recommend the Turbosmart Hyper-gate 45, but if you want a cheaper option I can also help out with that but the Hyper-Gate is really where its at for the waste gate.
The BOV is a v-band style as always and the WG flange is now the 44-45mm V-band style as well!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Superman09 is offline
Old 02-27-2014, 10:55 PM
  #103
Ok I'll check out those XS Power BOV, that wastegate is what I was looking into getting since my friend runs that on your V1 kit. {Theoretically}If I did end up going with a different BOV, I could just get one with a vband mount and it'd work, Correct?
Old 02-28-2014, 11:24 AM
  #104
Heavy H.P.'s Avatar
Oh yeah, Im IN!!!
Heavy H.P. is offline
Old 02-28-2014, 12:25 PM
  #105
LS1Tech Sponsor
Superman09's Avatar
There is 11 now!!! Everyone now can reap the benefits of another $100 off!
__________________
Old 02-28-2014, 12:26 PM
  #106
LS1Tech Sponsor
Superman09's Avatar
Yes, a 44-45mm V-band style gate! The v-bands very slightly from manufacturer but this flange fits most all of the popular brands (TiAl, Turbosmart, etc)
__________________
Old 02-28-2014, 04:59 PM
  #107
Heck yes just the answer I was looking for.
Old 03-01-2014, 08:07 AM
  #108
LS1Tech Sponsor
Superman09's Avatar
__________________
Old 03-01-2014, 02:00 PM
  #109
obZidian's Avatar
Nice looking kit pal!!
obZidian is offline
Old 03-01-2014, 06:04 PM
  #110
Is there enough clearance to run a slightly larger sway bar say a bmr or strano?
Its not a deal breaker but I would like to upgrade the sway bars from the ws6 package.
Old 03-01-2014, 08:46 PM
  #111
ChvyC10's Avatar
Any update on the a/c kit?
ChvyC10 is offline
Old 03-01-2014, 10:54 PM
  #112
LS1Tech Sponsor
Superman09's Avatar
I cannot confirm that at this time. We built the kit around the larger WS6/SS Style front sway bar so it will fit those as well as the smaller factory bars, however larger bars I cannot confirm on.
__________________
Old 03-02-2014, 03:12 PM
  #113
#12 was me. Looking forward to getting this!!
Old 03-05-2014, 09:30 AM
  #114
LS1Tech Sponsor
Superman09's Avatar
Back up! Down in the 11-20 person price bracket. Keep it coming, I am sure we can hit #21 to get another drop!!
__________________
Old 03-05-2014, 05:31 PM
  #115
Sales1@Texas-speed's Avatar
Bump for a great deal!
Aaron@Texas-Speed
Sales1@Texas-speed is offline
Old 03-05-2014, 06:28 PM
  #116
SSmoken's Avatar
QUESTION: ive got the V1 kit sitting here still unused. are these manifolds compatible (probably not) or would i need to buy the entire setup? i like the new design of keeping the radiator / low oil sensor / alternator in place. just thought id ask. thanks.
SSmoken is offline
Old 03-09-2014, 08:30 AM
  #117
LS1Tech Sponsor
Superman09's Avatar
This new V2 kit uses new manifolds that are v-banded and built to retain the OEM alt location. Therefore no, as these manifolds end in a different location and with a different flange. The new V2 crossover is built to mate to the new V2 manifolds. The first version crossover was made to mate to truck manifolds. Hope this makes sense!
Back up!!!
__________________
Old 03-09-2014, 12:35 PM
  #118
bboyferal's Avatar
Any room there for puller fans?
Looks good.
bboyferal is offline
Old 03-09-2014, 01:39 PM
  #119
SSmoken's Avatar
Back up!!!
That's what I figured. Thanks for the response.
SSmoken is offline
Old 03-09-2014, 10:50 PM
  #120
LS1Tech Sponsor
Superman09's Avatar
Looks good.
Thanks! I am sure with a little work you could fit a puller set-up. The pusher set up allows you to not have to touch the radiator or it's position and fit essentially any T4 turbo!
__________________
Quick Reply: ~NEW Huron Speed V2 Single T4 Turbo Kit *GROUP PURCHASE*
