Best place for oil return?
Old Feb 6, 2014 | 07:11 PM
HexenLord's Avatar
Default Best place for oil return?
Yes I know there are 50 of these threads. I just got a new Holley 302-2 and am reluctant to drill into it already. My old oil return was at the top on the side above the deepest part of the sump on a truck pan.
Has anyone successfully used the oil cooler feed/return for a turbo? Just asking because that's where my oil feed is currently. The turbo is up behind the passenger side headlight on my nova where the battery used to be. I found this on ebay.
http://www.ebay.com/itm/Dual-OIL-PORT-ADAPTER-1-8-NPT-gasket-Cooler-Pressure-Plate-LS1-LSX-LS-kit-/131069029140?pt=Motors_Car_Truck_Parts_Accessories &hash=item1e8452ab14&vxp=mtr
I might just tap the new pan on the passenger side, but if there's another way, I'd like to avoid it.
Old Feb 7, 2014 | 05:08 AM
samdogmx's Avatar
I return mine in the timing cover.
Old Feb 7, 2014 | 05:12 AM
silver_82's Avatar
You cannot return the oil from the turbo to the cooler ports. However you can supply the turbo oil from the cooler ports.
Ill add that the ports must both be used. You cannot use one port for the feed and block the other off.
Old Feb 7, 2014 | 08:13 AM
HexenLord's Avatar
Alright I'll probably just buy another fitting and find someone that can weld aluminum. The pan is off of the car now, and if I was going to remove the timing cover, I would probably go ahead and swap cams.
Old Feb 7, 2014 | 12:49 PM
stevieturbo's Avatar
That ebay piece is really weird !!
It looks like it will block all oil flow to the engine if you actually use one of those ports for anything ! lol
Maybe some oil pans are different though. But normally oil actually flows through the piece that is bolted on.
Old Feb 7, 2014 | 01:01 PM
Tanus's Avatar
this one would work.
edit-for the feed, for the return your gonna have to put a bung on the oil pan or timminng coverhttp://www.ebay.com/itm/4AN-OIL-PORT-ADAPTER-1-8-NPT-gasket-Cooler-Pressure-Plate-LS1-4-AN-LS-kit-LQ4/131105997384?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D19840%26meid%3D4673455800133662338%26pid%3D100005%26prg%3D8934%26rk%3D4%26rkt%3D4%26sd%3D131069029140%26
Old Feb 7, 2014 | 05:23 PM
HexenLord's Avatar
I have on similar to that for the oil feed right now.
Where is everyone getting the aluminum fittings that they are welding into the pan? I was using a brass bulkhead fitting, but I may as well weld it on this time so I don't have to worry about the nut on the back coming off.
Old Feb 7, 2014 | 06:15 PM
crazyelf's Avatar
Any of the weld in bungs from summit in the right material and your size choice should work. Just make sure they are weld in and have no coating on them.
http://www.summitracing.com/parts/sum-220062/overview/
Old Feb 8, 2014 | 02:59 AM
Anywhere that sells hoses etc will sell the weld on bits too. Earls etc
Old Feb 8, 2014 | 07:30 AM
herecomesboost's Avatar
x2
Old Feb 8, 2014 | 09:38 AM
silver_82's Avatar
It is for an external oil cooler, both holes are pressurized oil, one being for "hot oil out" the other "cold oil in". The oil flow is required to be in a loop, but one could tap into either fitting to supply oil to the turbo.
If you block off either fitting the engine wont recieve any oil
Old Feb 8, 2014 | 09:45 AM
1/8" NPT ??
I sure wouldnt want to be relying on that to supply my engine given the internal oil galleries are 1/2" diameter !
That piece on it's own makes no sense whatsoever unless it was used with other parts or after modifying the original pan to allow oil flow.
Old Feb 8, 2014 | 12:40 PM
silver_82's Avatar
Wow nice catch. I didnt even look at it saying 1/8npt. Thats way too small.
Old Feb 8, 2014 | 02:07 PM
HexenLord's Avatar
Yeah I'll probably just keep the one I have now that I got per Denmah's recommendation.
