Curious: Why don't cold sides require v banding (turbo)
Iim in process of building my turbo setup. Why don't cold sides use v bands like hot sides do? Just curious. Are there limitations there? (For the 1000-1200hp setups)
That part I know, obviously. Very obviously.
Someone just told me "to get the entire kit v banded" yet pretty much everything I see has couplers on the cold side and inter cooler and all that, except for 2500hp outlaw cars that v band everything.
It's just easier to use a coupler. There are Vbands cheapish on EBAY with an Oring in them specifically for cold side piping.
http://www.ebay.com/itm/CXRacing-3-V-Band-Clamp-Flange-Kit-Aluminum-Turbo-Intercooler-Pipe-w-O-ring-/290612657549?pt=Motors_Car_Truck_Parts_Accessories&hash=item43a9dd3d8d&vxp=mtr
i vbanded my cold side but left 2 couplers so it had some flex. 4" vbands were $60, and a silicone and stainless clamps was like $45. Worth it for the ease of never having to worry about popping one off
I have one Vband on my cold side at the turbo because it was designed for one. BW S476. When I asked, guys said they just cut it off and used a silicone coupler. I wasn't about to whack the outlet off a $1600 turbo.
The rest of my cold side uses 3 silicone couplers. Of those, the only one that could blow off is the TB coupler. The others physically can't.
All that said, I have not run the car yet, so time will tell.
Ron
Ron
My new Cold side will have 2 V bands and 2 silicon couplers.
That being said my old cold side had about 6 silicone couplers and I didn't have any issues until I was trying to go faster than my 8.62 pass. And I was only loosing couplers on the turbo side of the intercooler(it was a restriction) Probably seeing 30 psi on that side. only 19-20 at the Engine
Dont forget, that unless your engine is bolted solid, and the chassis is solid, creating solid pipework can lead to fractures.
Silicone couplers allow some movement so are better than v-bands in that respect.
I would never ever use a solid pipe system with any type of flexible engine mount.
Wiggins clamps etc would be the thing to use there, although they are very expensive. I think there are similar cheaper options though.
But certainly on 3" pipework Ive used up to 40psi boost with no issues with silicone pipes and good quality hose clamps
A lot of making them work is just common sense. Proper hose prep and clamps, or add a bolted strain relief across silicone couplers.
Obviously the larger diameter the pipe, the more force trying to blow it apart.
LS1Tech Sponsor
I was just going to post was Stevie said, well said!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
