how small of a turbo can i run?
I am not worried about going over that rpm. i will be running rhs heads and rhs efi intake. I want to put a smaller turbo on this setup say a 67mm and max hp numbers at 650. I am not going to go over that. i want to be able to run 3'' downpipe and i want quick spoolup this will be front mount. I am just wondering about housing sizes, size of turbo. this truck is a daily driver. thanks for any input.
67mm isn't too small. There are 62mm turbos available with T4 housings sized well for a V8 and are rated at 700+ hp if you want to go that route. This place is HORRIBLE when it comes to asking for turbo size recommendations.
The stock L31 computer will not go past 5800rpm anyhow, so I would be looking in the 66-68mm compressor range. Most I have made with a stock bottom end L31 was 480rwhp and it lasted at least 5 seasons and never had one problem.
