Where is your trans temp sender installed?
Old Mar 12, 2014 | 02:30 PM
adrynalinjunkie's Avatar
Default Where is your trans temp sender installed?
I want to install a temp gauge and also a temp switch to turn my tranny cooler fan on and off.
Is it better to put them both in the pan?
Or can I put them inline with the fluid coming out of the case before it hits the cooler?
What did you do?
Old Mar 12, 2014 | 03:14 PM
geoff17's Avatar
Mine's in the pan since my pan already came with the tapped bung in it.
Old Mar 12, 2014 | 04:42 PM
Shownomercy's Avatar
Man-Crush Warning
In the pan as a drain plug.
Old Mar 12, 2014 | 05:16 PM
willizm's Avatar
I have an Aeroforce obdII gauge and monitor it from the PCM. Not sure if it's the most accurate read, but seems a-ok.
Old Mar 12, 2014 | 05:23 PM
allout06's Avatar
im going to use a 1/4" to 1/8" npt union to go to the sender, then on the other end of the union add on a 1/4" npt Tee, with -6an to 1/4" npt fittings on each side and put it in line.
Old Mar 12, 2014 | 05:40 PM
SMOKNSS's Avatar
Im with the others above. Mine is mounted in the pan.
Old Mar 12, 2014 | 08:52 PM
LILHEMI's Avatar
temp gauge sender is in pan. thermostat for tranny cooler fan is inline.
Old Mar 13, 2014 | 04:00 AM
samdogmx's Avatar
I have 2, both in the pan.
