incon users....another question..noise
Man it smoked like a freight train for awhile!!! I'm thinking of undoing the butt pipe....and the compressor hoses and reverse flush with water. Any help?
Gary
Oh, on the scavenge pump power line...where did the line come off? I am finally getting around to fixing the rinky-dink setup supplied by incon and the installer, where the sense wire from the fusebox to the relay is connected to a fuse by a small lead. it's prone to falling off. I'm going to use the "etc" fuse location by putting in another lead/wire from a junk fusebox - that way there will be no issue with it falling off.
While on this subject I'm very happy to report last weekend I discovered what has been draining my battery ever since the turbo install at Detroit Speedworks (r.i.p.). They reversed the sense lead with the power lead, and viola', created a permanent 140miilliamp drain on the electrical system. Granted I don't drive or work on the car very much so it took me a long time to discover this. I have a page of turbo install fuckups I've corrected so far.
Boy does it ever look like the end of the world when the oil pump stops pumping! I pitty the fool who's behind me.
-Geoff
A relay has usually 4 and sometimes 5 terminals. the switching or sense Circuit is #85 & 86. Power through it activates a coil that switches the power circuit, #30 & 87 - the sense circuit uses very little current so most any 12v signal will work. When power is going thru the sense circuit, 30 & 87 are connected, allowing 30-40 amps of power to flow. on a 5 terminal relay there is a terminal 87A. When the relay is NOT powered 30 & 87A are connected.
I'm sure my car's situation was fairly rare. just basic installation screwup.
Gary
Gary, That is how mine is now. I really don't like how the wire attaches to a spade adapter that slips under the fuse. So am going to rig up the unused "etc" fuse and run the wires in from the bottom. less likely to malfunction and leave one stranded.
Did you hear about the setup elmer had done to his? I plan to do this when the car has some serious down time. He added an oil pressure sense switch in front of the relay, so the scavenge pump doesn't activate until the engine is running. With that setup it's not necassary to pull a fuse or wire when using ls1edit. I really hate the pump running when the engine isn't.
cablebandit - I guess as long as the window switch activates WAY BELOW the normal idle speed. Does the Harlan WS allow settings that low?
If so, it's a much better setup imo then tapping into the oiling system.
What do you guys think about those solderless jumpers that just piggyback the wires? I was going to try one of those for now, but I am unsure how durable they are.
-Geoff
-Geoff
Yep, only thing wrong with that idea is I didn't suggest it
damn good idea. I don't know exactly what the solderless jumpers look like but if it's made for tapping in it s/b OK. Maybe use a few wraps of a good electrical tape on top of it to keep it put and keep out moisture.
-Geoff
