What's the best fuel pump and injectors to run on E85
NoBreak....I have seen 044's on E85 get in the low 900rwhp range but they were at the peak of their efficiency. This was on a 2J Supra running 2200cc injectors not sure how that translates directly to lbs/hr
My low imp 120's were maxed at 950whp through an unlocked auto on a dynojet with 50psi base and 28lbs boost. Dual 044's ran out around 850. Added a third but changed the setup. Now looking for 1200w with 160s and a belt pump. 4303 pump runs out in the 900's in my experience. Holley pump is nice and quiet, not sure how far that one will make it. TurboBu has one on CrustyNova.
LS1NOVA, or anyone else, if dual 044s at 50 psi base were done at 850 with 120 injectors, would switching to 160s with like a 43psi base have the potential to make more power?
Restricted User
Denmah made 720 whp on a single 044. My old mustang is now making 660 through a single 044. I've seen countless cars making 600+ whp with a single 044. No way you should've been out of pump at 850 with 2 of them. Something else had to be going on.
