I could burn this POS to the ground....
Old Apr 27, 2014 | 12:07 PM
zapp109's Avatar
Default I could burn this POS to the ground....
Ive spent so much time and money on this thing and have no luck at all.. I have professionals handle like building the transmission and my longblock since im not familiar or comfortable with the internals. And first off after the dyno session the BUILT 4l80e loses reverse. So get it rebuilt. Notice it keeps losing coolant somewhere, but its not in the oil. Thats another issue im trying to figure out... But now THIS!!
300 miles on my car and well really only 1 true track pass on like 9 psi. The previous pass the car blew oil everywhere out my knock sensors.. so cleaned it,adjusted the tune since it was running really rich and did a full pass. After the pass oil pressure went down to 10psi at idle...
LQ4 Block 408
Mahle pistons
scat rods
eagle crank
317 heads with valve job
turbo cam
it goes on and on
with a bullseye s480r turbo
build here
https://ls1tech.com/forums/conversio...rbo-build.html
The pass, just took off no boost at all. Then she took off.
Here is what i found
Thought id feel better by venting but I think im more pissed after reading this..
Old Apr 27, 2014 | 12:33 PM
93camaro_zzz's Avatar
What is that bottom picture of? Sucks to hear the bad luck man. I can definitely relate with you. I just got done with 4 months of work on my car, and obviously thousands of dollars probably with this turbo build, and my car will not enter boost. Something spark related. Havent figured it out yet, but it was the biggest case of automotive blue ***** ever. You go out, the car starts to spool, and then RIGHT at 0psi, it stutters.
Hope you get a streak of good luck with yours!
Old Apr 27, 2014 | 12:52 PM
zapp109's Avatar
bottom pic is the oil filter, all the shiny stuff is metal
Old Apr 27, 2014 | 01:01 PM
b.lee's Avatar
An engine is only as good as it's builder... Same thing for the transmission
Old Apr 27, 2014 | 01:12 PM
yenkomike's Avatar
might as well pull it out and get it fixed . iv been there and done it but you wont feel any better till you get it right and get some runs in. I whouldnt run it any more just get it out and find the trouble. sorry about your luck .
Old Apr 27, 2014 | 01:14 PM
forcd ind's Avatar
and I thought you were cooking spare ribs
bummer, sometimes their trouble free, sometimes you wonder why you fool with them-I do my own trans, engines, etc, so I can only blame myself if something happens
you will get it going
Old Apr 27, 2014 | 04:36 PM
stevieturbo's Avatar
And none of the above is any good without a tuner.
But you say it blew oil out the knock sensors ???
Old Apr 27, 2014 | 08:05 PM
vwdave's Avatar
That sounds like an absolutely **** ton of crankcase pressure.
Old Apr 27, 2014 | 08:26 PM
Blackpanther99's Avatar
Gawwd, those little metal threads dont look pretty at aaaaall.
Old Apr 27, 2014 | 09:42 PM
zapp109's Avatar
Well this just cant be good...
on the windage tray
pick up tube
some random debris
Another thing i noticed how the oil looks very dirty
Here is what was going on with the knock sensor seal, it has a small tear in it and is bigger now from the tear so wasnt sealed
some more carnage near the knock sensor stud
Old Apr 27, 2014 | 09:54 PM
mr haney's Avatar
Man, I hate it for you. Hope you get this **** worked out.
Old Apr 27, 2014 | 09:56 PM
427zm's Avatar
Sharp looking fox! 5.3 JY that bad boy and get it running. It'll save you money and time.
Old Apr 27, 2014 | 10:03 PM
zapp109's Avatar
If i was running a t4 setup i would, this just makes me sick. And to top it all off my engine builder blew me off all day.... So im pretty pissed right now. See if he wants to work with me a little and make this right. Built turbo engine with 300 miles running 9 psi shouldnt have these issues..
Old Apr 27, 2014 | 10:06 PM
427zm's Avatar
I'd imagine he will especially if he wants referrals.
Old Apr 27, 2014 | 10:31 PM
MUSTANGBRKR02's Avatar
This is why my LME 427 is getting completely built by them and run on the dyno before it comes to me. I would start it up and run it into a wall if that was mine.
Hope your builder helps but be prepared for nothing.
Old Apr 27, 2014 | 10:59 PM
Alex in Houston's Avatar
^^^ Co-Sign --- Good luck getting an engine builder to accept any type of responsibility when issues arise.
Old Apr 28, 2014 | 12:25 AM
If he built the whole engine up to the intake and accessories then you stand a good chance. If he didn't and you installed the cam, heads and valvetrain then good luck as it could be his fault or it could be yours.
Old Apr 28, 2014 | 05:54 AM
zapp109's Avatar
He built the long block, I put on the intake and accessories. Definitely appears to be a bearing failure to me. We shall see today what he says.
Old Apr 28, 2014 | 06:55 AM
Hopefully it works out then.
Old Apr 28, 2014 | 07:12 AM
Camaro9969's Avatar
That sucks man I feel your pain trust me. I hope he steps up but that is rare if he does. It's prob just his bearing clearances were off which might not cost him too much money maybe machine the crank slap new bearings balance and go. Keep us posted
