Different Intake for vortech but had some trouble
Old May 16, 2004 | 09:59 PM
Justin98TransAm's Avatar
Default Different Intake for vortech but had some trouble
put a Cone filter on the MAF then the MAF to the Supercharger. After starting the car, it ran like crap, surging and such running really rich I could smell gas bad. You think that maybe the MAF being so close to the supercharger is causing turbulance and false readings from MAF? Or do you think that the airflow just changed so much it needs to be tuned?
Old May 16, 2004 | 10:38 PM
rons 00z's Avatar
looks like you had to move your coils. did you make sure your coils were gounded to something? i'm almost sure they have to be
Old May 16, 2004 | 10:39 PM
ahhh.. good point.. I didn't know this. and Good eye by the way!
Old May 16, 2004 | 11:07 PM
nope wasn't that. just went outside and bolted the two coils back to the valve cover, did the exact same thing. So I left the coils bolted like I had them and put the vortech intake system back on, and the car runs fine..
Old May 16, 2004 | 11:29 PM
Blackbird's Avatar
I don't think there is any way it's going to idle with the maf that close to the blower like that. where is the bypass?
also why would you do this? all that would do is pull hot air from the engine compartment and cause a loss in performance.
Old May 17, 2004 | 06:39 AM
Guido's Avatar
What difference does distance from the compressor housing have to do with anything? :wtf:
Old May 17, 2004 | 08:41 AM
slow's Avatar
first, you need straight pipes before and after the maf, for best results.
If stock, screened, you should be alright in a location like that... however, your dumping air back into the back of the maf, from the bypass valve, this is the correct place to put it (between maf and blower) , but that close to the maf, most likely has some bad effects on it.
You really need to move it farther away from the blower, for those reasons.
also, i would seriously consider relocating the iat to the discharge tube from the intercooler, makes for a more accurate reading.
Ryan.
Ryan.
Old May 17, 2004 | 08:53 AM
CHRISPY's Avatar
you are going to get some HOT air with the filter there. I would look at putting your battery in the trunk and run the filter down into the fenderwell.
That isn't an ideal setup imo.
Old May 17, 2004 | 10:09 AM
SSHOTROD's Avatar
im using a granatelli maf, i tried a similiar setup and vibrations killed me, once i dampened the virbrations it leveled back out, it worked, the car ran lean, so i left it alone till i decide to retune
Old May 17, 2004 | 10:43 AM
S_J_H's Avatar
If that valve on the discharge side is bypassing any air, then it's going to run horribly rich and will never work.
A maf on the inlet side must have all the air bypassed back between the blower and maf.To run an open bypass valve you have to have the maf after the valve on the pressure side.
I also think the air filter is in a bad spot, it gets real hot there. I even have my big 4" inlet elbow wrapped in therm-tech wrap to stop the elbow from heat soaking.
Compressing hot air makes the blower work harder,reduces it's output and it will tax your heat exchanger big time.
Steve
Old May 17, 2004 | 02:25 PM
slow's Avatar
S_J_H your right, i thought that line was the bypass, but looks like it might be a pcv hose?
too small for the bypass.
Thats the first problem, venting metered air, and then my description, is the secondary problem
Ryan
Old May 17, 2004 | 10:07 PM
Ryan
I've haven't run the bypass since I installed the supercharger. I've always had the BOV on it. The hose coming out of there is the PCV hose. The reason I was messing with it is becasue well, you never know until you try. Was also thinking of taking the idea further and pulling air in through the cowl somehow. This was just a step in the process.
Old May 18, 2004 | 03:23 PM
slow's Avatar
with n o bypass, the air can only surge back and forth between the TB and the blower.
you need more distance to make it work right, this is probaly part of why you had so much trouble in the past with your setup.
Ryan.
Old May 18, 2004 | 08:00 PM
Ryan.
my heads were the reason I had so much trouble in the past. I tried running the bypass when I was troubleshooting to see if it made any difference, guess what, it didn't. I know a guy running the same system as me making 625rwhp and he's also using a BOV not the bypass, the car's been running fine for over 3 years now.
Anyway, if I get a chance I may be playing around with this some more this weekend, maybe a longer tube between the MAF and the supercharger, or maybe gettin a MAF that still had a screen in it..
Old May 18, 2004 | 08:05 PM
slow's Avatar
definately try the screen, combination of the cone filter, and descreened can cause problems for a stock car, let alone a blown car
good luck.
I wish you luck, as i really would love to find a good place for a inlet without using the air lid, so i can use the ati plenum/intercoolers i have laying around for my custom vortech install, but i think it will be too difficult to make it work without much cutting
Ryan.
Old May 18, 2004 | 10:44 PM
Got Me SOM's Avatar
sorry but running a filter with a maf right there just doesn't look right.
does it work right, with the way its supposed to be setup?
