When does ls6 intake and throttlebody become a restriction?
Old May 9, 2014 | 06:53 PM
mike13's Avatar
Default When does ls6 intake and throttlebody become a restriction?
I know you can make big power with a stock throttle body and ls6 intake but at what point should you consider going to something bigger?
Old May 9, 2014 | 09:13 PM
sbcgenII's Avatar
Around the time your car requires a parachute.
Old May 9, 2014 | 09:18 PM
mike13's Avatar
I'm running 143mph on 10lbs boost.
Old May 9, 2014 | 09:25 PM
sbcgenII's Avatar
Damn. What is your setup? If you're only on 10lbs i would just raise the boost.
Old May 9, 2014 | 09:47 PM
HCI2000SS's Avatar
If you are running 143 mph in the 1/4 mile then it is restricting you lol
Old May 9, 2014 | 10:24 PM
CameronVic's Avatar
I trapped 139 at 3900lbs with one. I prefer plastic intakes for street cars, and I damn sure ain't paying $1000 for a fast one. Lol
Old May 10, 2014 | 01:00 AM
mike13's Avatar
390 W/ETP245 heads, GT50 turbo. 1999 Firehawk convertible 3700lb's I'm thinking of going to a LS2 with a 90mm throttle body.
Old May 10, 2014 | 05:56 AM
mrstepheneades's Avatar
Wasn't Mighty Mouse (Davids car) a ls6 intake when he sold to flash? And run 8.6s?
Old May 10, 2014 | 06:51 AM
a98ws6's Avatar
Will running a different intake, such as a Edelbrock, Holley, etc with a 102 hurt performance over a ls6? All things equal.
Old May 10, 2014 | 07:06 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
This debate will never end....
So take MM's car that ran 8.6s with an LS6 intake... say he swapped to a FAST 102mm, he might have run 8.4s or 8.3s....just tossing out a number.
With boost, flow restrictions are minimized a little because, well, the air is being pushed to where it wants to go, but it doesn't mean there aren't gains to be had by reducing those restrictions, but at what cost?
Something that might help at WOT, under boost, might make it sluggish out of boost and hurt overall drivability on the street. It matters to some, and not so much to others.
So in summary, an LS6 intake can take you to 1000hp if that's your goal, but a simple intake swap might then yield a 100hp gain.
Old May 10, 2014 | 07:52 AM
Boo"SS"t's Avatar
I believe he had his converted to accept a bigger TB.
Old May 10, 2014 | 09:34 AM
mike13's Avatar
Yep awesome combination, let me clarify I know you can make big power on the ls6 intake and TB, I'm wondering if by going to the bigger throttle body if it will make more power per lb of boost which in turn would lower the back pressure on the turbine side of the turbo.
Old May 10, 2014 | 12:16 PM
Dynospeed's Avatar
Back in 08 I ran a 8.9-9.0@155-156 with a 402 and 91mm @14 psi on pump gas. I didn't go any faster on 17psi but I never changed the ls6 intake, stock tb, or intercooler. It can flow some decent air but there are better options out depending.
Old May 10, 2014 | 12:19 PM
iliveonnitro's Avatar
I'm sure it's not a set number of hp gain (eg, "100hp by switching from LS6" or even a linear scale (eg, a % gain by going to a FAST).
Your theory is correct, though. I'm sure with a 143mph trap, you will get similar power at a lower boost. Sounds like your application is too specific for anyone to know exactly how much, though.
Old May 10, 2014 | 01:06 PM
mike13's Avatar
Thanks
Old May 10, 2014 | 03:19 PM
87silverbullet's Avatar
At 10 psi, I don't see a different intake helping you make more power. If we were talking 25-30 psi then maybe we could see your scenario playing a role.
If you want more power, I would just turn up the boost. Boost is free at these power levels. Intakes no matter what they are made of cost money. I like the free stuff when possible.
Old May 10, 2014 | 03:40 PM
chuntington101's Avatar
Surely this is down to the engine size / config not the boost you are running (assuming you not blowing the intake apart) or power you are making. Once the air is in the intake the engine dosent give a ***** what presure it's at as it will simply be sucking in higher density air. This is why ITB setups on turbo engines still give amazing throttle response.
So assuming you engine isn't chocked by the intake when in na form, and your not running **** loads of boost, in theory you should be fine.
A intake swap might bet more power but it should be in line with what happens na. At least that's my understanding.
Old May 10, 2014 | 04:40 PM
stevieturbo's Avatar
Probably not.
What size is your boost plumbing ?
Wasnt there a guy on the forum not that long ago who had some FAST intake and large TB with his blower, and he sold it and moved to the LS6....think it actually gained power lol.
Not enough to say it was better though. But certainly enough to say the FAST was not an upgrade at all.
Old May 10, 2014 | 09:12 PM
crashly's Avatar
90mm throttle body on 481 cubes
Methanol fuel
2880 hp....
Old May 11, 2014 | 12:11 AM
CameronVic's Avatar
Methanol fuel
2880 hp....
Damn man! Never seen an LS6 look like that! Almost looks like a 1271 or something!
