huron speed guys step in
Old Jun 27, 2014 | 03:52 AM
SPOOLED UP's Avatar
Default huron speed guys step in
What does your alternator look like now after moving to the top of the pass side head?
Pix and how much had to be cut.
I just cant put myself to cutting a brand new alternator covering smh
Old Jun 27, 2014 | 03:56 PM
JetMech99's Avatar
I dont have pictures, but I removed the entire plastic cover and spray bombed the whole thing in a black high temp paint. Looks pretty good to me! If I remember tonight, I can snap a pic for ya.
Old Jun 27, 2014 | 08:42 PM
SPOOLED UP's Avatar
Anyone else
Old Jun 28, 2014 | 02:53 PM
LT1RAY's Avatar
I used a 140a truck alternator and removed the entire rear cover.
Old Jun 28, 2014 | 03:50 PM
a-low's Avatar
Is it safe to use the alternator without the rear cover? The battery stud
on mine is a little too close to the fuel rail fitting crossover
Old Jun 28, 2014 | 08:42 PM
steveo_f8's Avatar
Have a truck alt now but before I trimmed the rear cover on the stock alt and yes it was close to the stud on mine as well.
Old Jul 3, 2014 | 02:23 PM
djt81185's Avatar
I did the same thing, tight to the fill neck but works fine.
Be careful removing the intake manifold if you have a metal one with a relocated alternator. Sparks will happen if you forget to disconnect the battery and having loose fuel rails with this makes for an exciting day.
Old Jul 4, 2014 | 07:19 PM
kylemm1002's Avatar
This is a huron alternator relocation kit.
I just removed the rear cover
Old Jul 4, 2014 | 10:26 PM
coolmanvette75's Avatar
Here is mine...
Old Jul 7, 2014 | 04:50 PM
Dzel's Avatar
My speed fuel rail is sitting where the alternator sits. I'm thinking of just getting some fittings and make it just go up? any other suggestions?
Old Jul 7, 2014 | 05:02 PM
Dzel's Avatar
Here's some pics
Attached Thumbnails huron speed guys step in-20140628_102604.jpg   huron speed guys step in-20140628_101236.jpg   huron speed guys step in-20140628_102539.jpg
