Rip cut a supercharger pulley - got some boost back!
Old 07-10-2014, 04:55 PM
FastKat's Avatar
Default Rip cut a supercharger pulley - got some boost back!
I found another legitimate use for my milling machine - to slash cut supercharger pulleys! I did this for a friend and he got between 1.5 and 2.5 lbs of boost back. We'll find out if it totally took care of the belt slip issue when he dynos it.
It was a fun and easy project. I'll post back when I find out how it held up on the dyno.
Old 07-10-2014, 06:43 PM
fire67bird's Avatar
Interesting. I wonder if relief cutting on one side of the channel you milled will allow the belt to dig into the groves you cut some more.
I came across this link when I googled what you were trying to accomplish with the mill groves. Has some good info on how to reduce slip.
http://beltslipsolutions.blogspot.com/
Old 07-11-2014, 11:14 PM
FastKat's Avatar
Thanks for the link.
Interesting idea on the reliefs. I'll have to look into that. I've never really given much thought to how it worked but now I'm curious!
Old 07-11-2014, 11:30 PM
SilverSS's Avatar
I hand cut slits on my pulley with a dremel way back in the day. It was ugly but worked well.
Old 07-12-2014, 12:31 PM
Monte4ever's Avatar
Keep us posted. I want to know how this turns out.
Old 07-12-2014, 09:27 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Interesting. I'd guess that it would reduce the life of the belt by digging into it more, but if it works, then it's worth buying a new belt each year.
Old 07-12-2014, 10:56 PM
8 Second Truck Club
Blown06's Avatar
Did Reichard have a patent on that process?
Old 07-13-2014, 03:29 AM
stevieturbo's Avatar
I had it done on a couple of pulleys ages ago. Didnt make one bit of difference.
Old 07-13-2014, 07:59 AM
Old School Heavy
speedtigger's Avatar
It will be in ntetesting to see how that affects belt life.
Old 07-13-2014, 02:40 PM
FastKat's Avatar
Thanks for bringing this up. I just searched and found the patent. I don't want to get into it here but I think what I am doing is substantially different.
Oddly, the Reichard patent talks about extending belt life. What I did here does not have those features.
I should know more accurate results this coming week!
Old 07-13-2014, 04:29 PM
bRAZENLS2gOAt's Avatar
subbing for the results
Old 07-14-2014, 12:14 AM
8 Second Truck Club
Blown06's Avatar
I can tell you this........I've used the Reichard pulley and it makes a hell of a difference and does not appear to wear the belt too bad. This mod works if done correctly.
Old 07-14-2014, 03:44 AM
Do Reichard not also coat the pulleys or something though ? or leave some sort of rough finish that helps with grip ?
Old 07-14-2014, 08:16 AM
UNDER PRESSURE MOD
So help me out here, what's the deal with the Reichard pullies? I did a search and only find them for sale. I'd like to know more about them, like why they drill holes in them, is it to lighten them?
Old 07-14-2014, 04:23 PM
The slots and holes are allegedly to prevent air getting trapped under the belt, which in turn can lead to reduced grip.
Which given the belt/pulley speeds involved, is plausible.
Reality ?? call Mythbusters
Old 07-14-2014, 05:11 PM
UNDER PRESSURE MOD
Interesting concept, and I've seen places where they say they offer a guarantee to add 1.5-2psi. If that's true, then it's worth the $150. But with Aster's bracket, I don't know how much belt slip I'm actually getting.
Old 07-15-2014, 12:26 AM
8 Second Truck Club
Blown06's Avatar
The thing about Reichard is that they never answer the phone and don't sell these on a consistent basis. I believe they have government contracts that keep them busy and $$$. From what I heard, he has no interest in doing these anymore. Hence the reason I'll never sell the one I've got. I assume most feel the same, that is why you hardly ever see them for sale. It took months to get mine direct from him back in 2009.
If you find one, ****** it up.
Old 07-15-2014, 05:37 AM
UNDER PRESSURE MOD
Thanks for the info.
Old 07-15-2014, 08:22 PM
FastKat's Avatar
UPDATE: After a street tune, the rip cut 2.38 pulley is now holding a peak 18.5 lbs with an overdrive crank pulley and Metco idlers, as logged with HPTuners. I think the overdrive crank pulley is a 10.5 or something like that.
Hopefully he'll have some dyno results later in the week.
It looks like I got the earlier data wrong. With the stock crank pulley: Before the rip cuts on the 2.38 pulley, the supercharger peaked at 14.2 and dropped to about 11 lbs. With the rip cuts on the 2.38 pulley, it peaks at 14.9 and holds it out much longer, eventually dropping to 12.9 lbs.
If it'll hold 18.5 lbs, I imagine holding 14 lbs without slip should be a breeze.
Old 07-15-2014, 09:40 PM
UNDER PRESSURE MOD
So who offers those rip cuts or do you have a DIY?
Quick Reply: Rip cut a supercharger pulley - got some boost back!
