Why are there so few twin turbo setups on here?
#61
#63
Take two turbos in sum that have the same compressor and turbine flow capacities as one single and according to you the twins will "****" on the single....... where I say it will be similar
Quite opposite really
#65
7 Second Club
How does somebody think that a twin setup that adds up to / is similar to that of a single setup in compressor/turbine flow, etc is going to be automatically better as an end result? I mean it's pretty similar at that point just done a different way for packaging constraints, etc.
#66
Ask the guru. He knows something everyone else doesnt
#67
#72
If I was on a computer I would go into detail plot for a given engine and show turbine but not on my phone
Let's simply look at the published compressor maps from a same mfg. Of different sizes
If you look at the 58mm gtx compressor you can see a pair is in the realm of a single 80mm gtx compressor....... not a 100+ lol
"****" for max effort? Again no, if the twins would have the edge it would be in transient response.... not all out power
Yes you get to a point where a single can not stay with twins...... but why is this?
It is simple, turbine capacity.
The largest commonly available turbine out there to drive a single compressor is the G trim.
Compare that single G trim to a a pair of gt55 turbines which are used in the promod stuff and it isn't even close, not one bit
#73
There are a few more points I'd like to touch on but I don't have time or the effort to argue with you right now I'm at work on my cell. Your knowledge of turbos is greater than mine to boot. I do however know one thing, I have been in and around enough single/TT cars to know what works best for me and 99% of the people at my local track and meets. Single turbos are great and have there place but in the end twins take the cake as far as I'm concerned.
#75
7 Second Club
I never said of similar turbine sizes, rotary did. The whole reasoning for me to go with twins is to get the greatest amount of Turbine/compressor in my car without having to deal with the consequences.. (single turbo) it's quite simple actually.. What would you rather drive? Twin 58mm turbos or a single 100+MM turbo.
I commented on it because of these two gems here.
#76
I'm aware of who said it, I was wondering why you would try to compare something that isn't similar? Normally if you wanted to make a point you would compare similar flowing setups with the only difference being single vs twin, not something completely irrelevant. I commented on it because of these two gems here.
Question #1: How does somebody think that a twin setup that adds up to / is similar to that of a single setup in compressor/turbine flow, etc is going to be automatically better as an end result?
Question #2: I was wondering why you would try to compare something that isn't similar?
Let's try to stay on the same page here...
#78
7 Second Club
Are you? Becuase you seem to be asking contradicting questions and some how labeling them as the same?
#80
Here is a good question I'm honestly interested in hearing the awnser to. Besides money/space/complexity of a twin setup why did you choose a single over a set of appropriately sizes twins? I'm generally curious as I'm clearly biased towards twins. Maybe I can learn something today.
