dynoed sts kit today
Old May 22, 2004 | 08:46 PM
amacgt's Avatar
Originally Posted by eviltwins
Only 527 torque from a small turbo when you're making 540 RWHP, what gives. Somebody actually host those graphs on this site so that people can see them.
the 5psi graph is on the first page tommorrow or monday i will post the 10psi.
the torgue is due to the big exhaust housing. I am going to put a size smaller one on it this week.
Old May 22, 2004 | 08:58 PM
MIGHTYMOUSE's Avatar
pretty neat for sure, some thoughts..
turbotech kit with t76 = 5,100
sts kit is 3,800 + 500 methanol kit + 800 headers = 5,100
turbotech includes a bov does this system?
this gt67 you're running is an upgrade, how much extra was that?
smokinhawk put down like 512 mustang dyno @ 10psi on a LC motor and the tt street kit.. wonder if that was pump gas or race gas? this would be roughly 540 dynojet give or take.... though that was like 2 years ago on an ed wrong tune
Old May 22, 2004 | 09:37 PM
amacgt's Avatar
The sts kit we sell for 3600. Methanol is not a must, upgrade is 400, and you dont have to have headers, The turbo tech kit you have to get injectors and pump instead of methanol, Must program computer for injectors, but if you want to run alot of boost on the sts kit you also have to do computer work, sts kit is way easier to put on. I like both kits but after dealing with both i like the sts more. The sts kit comes with a tial wastegate. Also with the sts kit if you want to run alot of boost 15 plus you can, all you have to do is upgrade turbos, If you want to run alot of boost on the turbo tech kit you have to get their race kit which is between 7000 and 8000. They both have their goods and bads. Just my opinions
Old May 22, 2004 | 10:08 PM
frcefed98's Avatar
I would just go with larger injectors 38's or 42's and programming and forget the meth all together or leave it on to fine tune it under boost.
Old May 22, 2004 | 10:29 PM
they are using the methanol instead of an intercooler far as i know. both kits of course need a pump and injectors at this level so i didnt count that in either total.
amacgt, of course you dont HAVE to have all of that stuff.. but if you dont have it your're not going to get the 500hp you did.. i am comparing the prices as they are used if you want to compare the results i think its only fair.
Old May 22, 2004 | 10:39 PM
frcefed98's Avatar
Ahh yes, I forgot there was no intercooler. With my PD, I had the stock injectors(28's) FMU running 6psi and ed wrong tuning non intercooled. The car ran excellent with those mods....except on real hot days then it was ping city. So I can see where the Meth helps, but I still would find a good intercooler before I used meth inj.
J
Old May 22, 2004 | 11:10 PM
byarddog's Avatar
Default STS turbo
The website is WWW.STSTURBO.COM.
On my kit I got a switch, the switch can be dialed up to 10psi from 5psi. Also when i want more boost I can change the waste gate spring and then use the switch from 10psi to 15 or so. I dont have menthanol yet so i havent used the switch just keeping it on 5psi and a good tune. I put in 42.5lb injectors and 103 auto lights. With the heat we back out the timing for pinning but it works great. any questions feel free to ask
Old May 23, 2004 | 08:26 AM
Tudds's Avatar
This kit looks better and better
Old May 23, 2004 | 08:27 AM
soundmaster's Avatar
1/4 mile times yet? or estimate?
Old May 23, 2004 | 12:46 PM
byarddog's Avatar
Default 1/4 mile time
I ran the quarter up in vegas a couple of weeks ago at 5lb boost
1/4 12.4
60' 2.0
mph 116.7
I now have a better tune and a new clutch going in, but the gears need to be changed they are 410's from my old set up and I was bouncing of the rev limiter just before the line. I should be in the low 11's with the proper set up and if i hit the switch to 10psi who knows where ill end up. later
Old May 23, 2004 | 01:10 PM
BigPlanTransAm's Avatar
the intake pipe itself acts as the intercooler, its like having a regular intercooler with no tubulators. theres little pressure drop but not as much heat exchange as there would be with a huge FMIC. the methanol does help cool the charge but it also adds the fuel to make more power than the stock fuel system can support. i would still reccomend upgrading the fuel sys just for safeties sake, but abviously the meth should be o.k. for a while.
Old May 23, 2004 | 01:14 PM
  #32
Excal's Avatar
great numbers...beasically no reason to get a TTI kit unless you're going t-76 and then you'r talking a whole different league as far as $$$. Sucess.
Old May 23, 2004 | 01:26 PM
  #33
BAD ASS TA WS6's Avatar
BMW ///M Nerd
Still weird as hell though...the idea anyways.
Old May 23, 2004 | 03:00 PM
  #34
Excal's Avatar
also the horror story ratio is much better, i've seen numbers not much better than that after 8k often in this forum.
Old May 23, 2004 | 06:08 PM
  #35
Y2kforgedSS's Avatar
Hey andy whats up this is Josh I see you took your car, didnt know you were on ls1tech, so what truck did yall dyno cause thats pretty good a truck. Ill be coming by next week to pay for my turbo set up and i hope i make around that much hp as you did at 10psi but do u think it would hurt my stock bottom end to run 12psi when i race. thanx man and ill see you later.
Old May 23, 2004 | 06:59 PM
  #36
smokinHawk's Avatar
it was on pump gas 94 to be exact. Tuned by DSI
ill admit these are performing better then i thought and can be a cheap upgrade with desent power gains, but if you compare the TTi kit, least on mine power comes on sooner. the sts kit looks a little peakier, while mine seems to have a broader power range, we will have to wait and see the 10lb graph first.
i got my TTi kit for $3k so it was $600 cheaper
Old May 23, 2004 | 07:41 PM
  #37
amacgt's Avatar
hey josh, the truck we dynoed was coles. I would not run above 10 on a stock bottom end. talk to you some more this week.
Old May 23, 2004 | 07:58 PM
  #38
hey cool, umm im thinking about doing a head and cam setup also when i do my turbo what head and cam setup do u think i should go with? and how much could cole get it for.
thanx josh brown
Old May 23, 2004 | 07:59 PM
  #39
BlackCamaroSS02's Avatar
Nice numbers! for the money there is no comparison cause with the TTi kit you have to take into account that its gonna cost a good amount to have it installed and with the STS kit you can do it yourself...atleast with me i wouldnt want to install something like the TTi kit myself. Going to order one in a fae weeks
Old May 25, 2004 | 03:16 AM
  #40
hondadream50's Avatar
For me $3600 is alot of money.. Past couple weeks I been searching wrecking yards for turbos I can use on my car.. I hoping to have around $500 total in it after Im done..
